Drilled Flywheels
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: Drilled Flywheels
    Posted: 22 Nov 2014 at 4:55pm
Question:
Did all the Briggs Vanguard engines & Kohler Command twins have the flywheel drilled and tapped to accomadate a driveshaft for a Garden Tractor. Just kinda curious. I'm lookin' around for a Kohler Command or Briggs Vanguard engine for my hotrod 716H. I missed the one that I was supposed to go see. Information was a couple weeks old I found out later... Sheesh!
Steve@B&B
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2014 at 6:48pm
the flywheels on both should be ready to accept approrate stubshafts or adapters yours may h aveto be redrilled [flywheel adapter] i think the old k engine is a little diff bolt dimenshions
Crewchief View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crewchief Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2014 at 8:33pm
Hot-rod'n a lawwwn mowwwer?
1952 B   1950 Ferguson TO-2O
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2014 at 9:35pm
Yeah, Yeah like that! Leave it to a Drag Racer to have a hotrod lawn mower! Way ta' go Crewchief! Here's the wifes hotrod lawn mower. I still got a ways ta' go wit my 716H
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2014 at 11:11am
ITS ABOUT TIME to see a picture of that i have been waiting to see that  sure looks sharp has it been hooked to the sled yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crewchief Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2014 at 7:16pm
[QUOTE=Steve in NJ] Yeah, Yeah like that! Leave it to a Drag Racer to have a hotrod lawn mower! Way ta' go Crewchief! Here's the wifes hotrod lawn mower. I still got a ways ta' go wit my 716H
[/QUOTE
Looks awsome Steve].Mine 'll b more Rat Rod lawn mower.I'll post a new pic,maybe next week some time.Rims were painted red a few days ago,and I'm in the process of painting the wide white walls today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2014 at 7:53pm
Thanks Hud for the info! I'm lookin' at a Briggs Vanguard on e-bay. It has a re-coil on it, and also electric start. I'm wonderin' if I remove the re-coil, if that's going to reveal a drilled flywheel in order to hook up ma' driveshaft for my 716H. I can fab a new adapter if the bolt holes are different.  I tried to get the wife to pull the finish mower around and mow the property, but she says that slows her down to much. I'm probably better off with her not doing it. There probably wouldn't be any lawn left after she gets done tearin' it up!! LOL!  Crewchief- I like the rat-rod look! I was thinking about stretchin' the frame on the 716, but I don't want to git' to carried away with it. I have other projects that need to get done also which I don't have a lot of time for...
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2014 at 11:32am
i will get the stubshaft  pn. looked up for you,  its not to expensive
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 7:00am
Hud,
I see one of those adapters on e-bay. It was off a 16HP Briggs in a Cub Cadet. I would imagine its the same? Not sure.
This page was generated in 0.143 seconds.
