Drill Dr. ?'S |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Nov 2019 at 3:45pm |
Anybody have 1 and have success with it? Old pal Larry tells me to stop buying them throw away HF drill bits and get 1 to sharpen all my American made bits. I might take him a box full and see what kind of a job he can do with it. Thanks guys. Hope you all gots all the left overs cornsumed.
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34204 |
I drag mine out from time to time, but only similar to my reloading supplies, when I absolutely have a mess of them to deal with as is a PITA for initial setup.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54292 |
Get the kit, with the video. I sharpen a couple hundred, atta time, generally when its cold/frozen out. It does work, but your eyes have to be good enuff to see what you're doin...
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8365 |
Thy are not as easy to use as it should be , aggrivatting to say the least
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88242 |
I learned to sharpen them on a 6 inch bench grinder by hand 40 years ago... Have never used the machine.
And I did too in Ag shop,, weld 2 5/8,s nuts together match it to the bit and you have the angle right,,
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
Well,,I git two of them Drill Drs,,,one of them never been out of the box,,but after fighting the one for so long,,I finally quit using it. I I learned to sharpen them by hand on a bench grinder from a gentleman on a Metal lathe Forum. He explained the procedure so well it was amazing to see how easy it can be if you pay close attention to the drill bit.
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
I have a different brand that I use for 1/4” and smaller.
Like Joe, I learned to sharpen by hand on a bench grinder. My eye sight isn’t what it used to be so I’m not much of a hand at it anymore. |
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
utoSpeed - Sharpening Drill Bitswww.autospeed.com/cms/article.html?&A=112910 Sharp drill bits that have the right shape for the job speed up the work, allow holes to be drilled with greater accuracy, and are less likely to cause accidents. But when you begin sharpening drill bits, take it slowly and carefully, checking the performance of the drill bit and ensuring that correct grinding procedures are being followed ... B:-) Dnoym
I still sharpen 1/4" and larger on the grinder, those I can still 'See', the ones I cannot so well see I use the Doctor on
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
I like my Drill Doctor. I don't wait for my bits to get real dull, I touch them up as I use them.
I also learned how to sharpen drill bits is HS shop, but went too many years not sharping bits and lost my touch. My Drill Doctor works very well. And I fine it easy to use. Dusty
Thanks guys.
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
https://s3-us-west-1.amazonaws.com/hmt-forum/sharpening_enormous_drill.mp4
Edited by chaskaduo - 01 Dec 2019 at 5:19pm |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24732 |
no OSHA or Union there !!! no safety glasses....
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I got a Drill Doctor when they first came out, never could get a good sharping from it. I would like to learn the art of sharpening them by hand, right now I buy cobalt bits and don't have a problem with dull bits anymore!
