Dream tractor |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4234 |
Topic: Dream tractorPosted: 28 Jan 2026 at 7:54am |
Someone on the Red board started a thread like this. Couldn't help myself, had to do some dreaming. The one I 'dreamed up'.
A WD 45 with a 5.9 Cummins, 12 speed power-shift, 185 final drives, and 20.8x34's. Upon further reflection, might even throw in a diesel ring and pinion. It would be plenty fast with the 5.9 and 20.8's! I realize this is true fantasy but hey, it would be fun!
DanielW
Posted: 28 Jan 2026 at 8:31am |
I always thought the best of all worlds for the tractors I'm used to would be an Allis 180/185 engine, front-end, hydraulic system, and layout (with their high-up platform seating position), but have the 8-speed tranny and rear end from a Ford 5000/6600 - including the independent PTO. Though I'd keep the Allis draft control system over the Ford's, and wouldn't mind the PD as well. I love the Allis 6 cyl, seating position, layout, hydraulics and look of the 180. But those Ford trannys and rear-ends were uber-bulletproof and could be abused to heck without issue. I'm quite certain if any of our Allis's were abused like our Fords have been for logging and working in the gravel pit, we would have had jumping gear issues and rear end failures years ago. But our Fords keep taking the abuse without complaint - well over 10k hours. I'd far rather be sitting on an Allis however: They sure got layout and hydraulic system right when they designed the 180.
I'd probably also have 30" rears on there, as I always thought the 180's looked a little too squat on the back with the stock 28's.
Edited by DanielW - 28 Jan 2026 at 8:37am |
youngorange2000
Joined: 27 Mar 2019 Location: eastcentral MN Points: 323 |
Posted: 28 Jan 2026 at 11:15am |
Mine would be if the 100 series had true clutch pedal independent live pto
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4042 |
Posted: Yesterday at 9:59am |
ibwd mike carry that one step farther shorten up the steering relocate the battery and put the super deluxe seat up on a flat floor
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3601 |
Posted: Yesterday at 12:44pm |
Not today but IF in the 1960-70's - Start off with the IV D17 (170) - change the torque housing to accept the 7000 wet type PTO and power director clutch 3 speed - remove 1st gear to allow for syncros and move the PD torque gears down a bit. Use the 3 speed for a 9 speed trans - put disc brakes on as some of the pullers have done and power it with the 4.33T as in the 6060 - the a 2800 at 75 HP for the pullers to be legal - then 4.33I up to 85 PTO - switch to the bar axle to with the 301 at 105 and 118 HP as in the 7000 -
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2222 |
Posted: Yesterday at 1:58pm |
The 80xx, especially power shift, needed more gear selection. It needed a 3 speed rear end. It would have been a real update over the 700xx. I still enjoy my ps 8050's as is.
Leon B Mo |
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1961 |
Posted: Yesterday at 2:01pm |
I wanted to put the 4.33I into a WD45 or a D17.
Edited by TedBuiskerN.IL. - Yesterday at 2:15pm |
Unit3
Posted: Yesterday at 2:31pm |
Fun question!!! Allis Chalmers steam engines, AC hit and miss engines or more of the 2 cylinder engines like Fred has.
I would have liked to have seen what Gleaner could have done with a 6080 and 8010. I can imagine a hydrostat transmission and electro hydraulics. The side council in the 8010 could’ve looked so far ahead of its time. |
DanWi
Posted: Yesterday at 2:49pm |
Love the late 190's or 200 but could use a few more gears between 5/6 and 7/8 and make road gear faster. Have never driven an 8000 series, thinking they would fit pretty good on the farm. Friend has one of every model, 8010, 8030, 8050 and 8070, but life is busy and I never get over to his farm any more to help him out otherwise I would probably get a chance to drive one. I think the Agco DT series was heading in the right direction, powershift or CVT transmission. Cumins motor and later Sisu. The one my friend has I have driven and other then some nagging electrical issues I think it has been a good tractor.
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2161 |
Posted: Yesterday at 4:23pm |
I agree with the two stage clutch with the 100/200 series tractors. That would have been nice. My one-sixty has it, so why couldn't the other 100 series of had them? Also, I like the power director on the D series tractors rather than the one on the 180, etc. The 170 had the had clutch that was nice and easy to use. Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1011 |
Posted: Yesterday at 7:14pm |
Just think how iconic the 190 would have been had they put the correct brakes ,PTO and rear end. Gearing so that a jogger couldn’t out run it…..it was SO close to have been perfect.
Les Kerf
Posted: Yesterday at 7:41pm |
My dream tractor would be a Series 4 D17 gasser. Stock. In mint condition. Dream on...
DanWi
Posted: Yesterday at 10:21pm |
How about a black belly 7080? Or if you make it a dream tractor 8.3 Cummins and a full power shift trans.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 138 |
Posted: 23 hours 50 minutes ago at 12:08am |
I think for me it would be a 2wd 8010 with powershift for baling, although not sure it would be much of an improvement over the 190XT. I also think I would like to have a SeriesIV D17 with three point, maybe a diesel with a 433 conversion.
Ted |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1260 |
Posted: 5 hours 49 minutes ago at 6:09pm |
Think mine would be an 8550 with a Allis 844 and of course the twin turbos…
Even to drive one would be fun. I dream of someday to have an Allis museum, sorta like the one that used to be in my town except to go from the start of Allis to the end (plus a few extras).
Unit3
Posted: 2 hours 2 minutes ago at 9:56pm |
D21, 210, and a 220 with 540/1000 PTO. I sometimes wonder why there isn’t a D21 on this farm and if you only knew how close I came to having a 220FWA. Oh to turn back time.
