drawbar length |
Bob(FL) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Cape Coral, FL. Points: 1323 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Nov 2009 at 11:30am |
What would be the best length of drawbar for pulling a wd45 diesel, short or on the longer side, thanks.
R Aiken ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: wc Ohio Points: 1370 |
Short for pulling heaveyer loads, easyer turning and stronger when short. Long for pto.
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 915 |
Are we talking about competitive tractor pulling? If so, even with the 45 diesel being heavier in the front than a similar gasser model, my observations are that the best ones still go about as short and high as the rules allow. Kip
Yes I need to pull the 45 some, it is starting to run a little poor from doing parades and drives, might as well be competitave.
If you can't float the front end short, you can try longer, but I'd still go as high as you can. Kip
