Draw bar vs. PTO attachment height for mowers
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Topic: Draw bar vs. PTO attachment height for mowers
    Posted: 23 Aug 2022 at 5:49pm
So I moved the mower from the old pin hitch draw bar WD to the snap coupler draw bar WD (with both hitches set all the way to the rear). The snap coupler one the PTO shield would hit the top of the hitch bracket, so I adjusted them apart...
Debating on whether or not I should raise the hitch one spot to compensate a bit to make it all run more level (which would drop the front end of the mower down a bit), but it mowed good for a solid hour this weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2022 at 5:55pm
why mess with sucess ??
maybe do the entire field ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2022 at 6:18pm
Having an OPERATORS manual for both the tractor and mower would give specific adjustments to make to both for proper operation.
  For PTO work most any tractor SHOULD have the drawbar adjusted to A.S.A.E. dimensions. That being 14" back from the end of the PTO shaft and between 13" to 17" from the ground. Any implement should be level when in operation so the hitch & PTO need to be adjusted accordingly.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2022 at 8:36pm
Take your torch and cut an inch or so off the top of the 2 vertical supports on the mower tongue, will give more clearance for the PTO Shield.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2022 at 6:36am
jaybmiller -- it did seem to work nicely
PaulB -- I do actually have both the tractor operator manual and one for the 160/172 series rotary mower. I know it talked about how to level the mower front to back (slight slope to the front) but I don't recall exact measurements. Will have to check on the 14" distance from the PTO shaft and the ground clearance.
Gary -- Haha.
