draw bar mounted brush hog
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: draw bar mounted brush hog
    Posted: 28 May 2012 at 10:43pm
How common are the 4' draw bar mounted brush hogs that you see on the back of a c or b? Anyone know what they worth? Also, were they a standard option or accessory for the b and c?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 10:57pm
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 1:56am
see them on sales all the time, i wore one completly out. it musta been 50 years old!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 6:43am
Tucker, the mower I am talking about looks different than that one. The one I have seen hooks up at two points on both sides of the draw bar. Kind of like to trailer hitches on one trailer.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 6:51am
The only thing I ever saw like that would be a Farmall Fast Hitch. Are you talking about a 3 point set-up? Lots of 3 point kits have been added to B's and C's and a 3 point mower is probably more common than any other set-up.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 7:31am
The one I have seen looks more like a two point.
Can't fix stupid
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 7:45am
he may be talkingt about a custom made set up..
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 10:39am
Its possible. It sure looks original but anything is possible. I have a pic I can email someone to post on here because I don't know how to post pics on here.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 11:13am
lucasahas@yahoo.com
German Shepherd dad
#WD234847
#WD88193
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 2:22pm
Picture emailed
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 4:12pm
Im not sure about this one, it almost looks shop built.
Edited by AC WD45 - 29 May 2012 at 4:14pm
German Shepherd dad
#WD234847
#WD88193
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 8:16pm
I figure it's shop-built, but I kinda like the idea. Recon the hydraulics would lift it if you put a rod from either side of the rockshaft down to the deck? Imagine you would have to put some weight out front of the tractor, but it might work.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 8:39pm
Better have a stump jumper on that one, YIKES. No hydraulic lift would be a real pain unless you are just scalping the yard with it.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 7:11am
Hmm!  A semi-mounted bush-bob...  If you used lift links from the rockshaft with a cultivator depth crank to set the cut height, and a remote cylinder to lift the back via a 2-way plow valve, that would be a neat little rig!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 7:12am
I( suppose they would, I cant tell whether the hitch is stationary or hinged, If it wasnt hinged you would want your bar more toward the back of the machine, alf lift the whole thing a few inches. It looks like it has caster wheels from TSC or a surplus shop on the rear
German Shepherd dad
#WD234847
#WD88193
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 10:09am
The way it seems to hook on is with two trailer hitch set ups. What would everyone be willing to gamble on this?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 10:14am
I took classes for fabrication and welding. The hitch bar assembly/setup looks original or who ever did it did an awesome job! because if you look closely at the two bends in the bar on both side where it hooks up, those were bent with a machine and/or done professionally. They are very clean bends for being a jerry-rig setup.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:08am
they look like bends are bends up to me. My deer blind trailer (an old folding trailer) has the same bends in the same places
German Shepherd dad
#WD234847
#WD88193
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:14am
The " hitch couplers" are retro also.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:17am
those are interesting, they look like they are incorperated into the bar. I would love to see more close ups of this set up.
German Shepherd dad
#WD234847
#WD88193
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:23am
Would it be a safe assumption to assume that this isn't allis?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:44pm
definatly
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:57pm
The gearbox design and mount remind me of a Bush Hog brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 2:59pm
I would say that someone took the tongues from two small trailers or car dollies, removed the existing trailer hitch from a Bush hog flail mower, and installed them in it's place. They then removed part of the existing axle from the mower, welded on the rear "box", then put the swivel casters on there. Geometry is all wrong on the casters. They wouldnt swivel right with the mower raised much higher than it is now.
It could be reworked with a different frame for larger casters, and would be pretty nice. Would still want a way to raise and lower it with the tractor hydraulics.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 7:54pm
Not sure I would risk much money with it then
Can't fix stupid
txharnish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote txharnish Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 7:58pm
I just inherited a 1939 Allis-Chalmers Model B and would love to get a rotary cutter to spread my 6 acres of Coastal Bermuda here in Central TX... but all I'm finding are rotary cutters for tractors with a 3 point hitch.  What's the best path for me to take:  keep looking for a rotary cutter that will work with my drawbar (and 560rpm PTO) or add a 3 point hitch conversion? Regardless of which option you think is best, can someone point me in the right direction on where to get one?
theropod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 8:44pm
I have one and it is driven by a big V belt. I will never use it. I will post a picture of it tomorrow. Mine was used with my 38 B. Have no idea if it even works.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200
No private messages:
use email:
theropod AT yahoo DOT com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 8:55pm
The ball mounts look like from a one wheeled trailer from teh 50 s ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 8:57pm
Woods L59 belly mower. Can’t say I have ever seen a rear rotary cutter on a B. I’m sure someone has one but I haven’t seen one.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 2:50am
John Deere used to make  small rotary cutters like that back in the early 1970s and there are probably a few of them still around.  They had a tongue that hooked to the drawbar and  it was lifted by the remote cylinder and two wheels on either side of the back of it.   We had one because we had a Massey Harris 44 which has the PTO high up on the back of the tractor above where the bottom of the top link hooks on making it utterly it useless for PTO driven three point implements.
I think the one we had was either a 509 or 609.  It basically looked like this but was half as wide.
http://www.deere.com/en/cutters-shredders/rotary-cutters/hx10-rotary-cutter/
Edited by VAfarmboy - 04 Dec 2017 at 2:52am
This page was generated in 0.118 seconds.
