D-R starter-geneator
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-R starter-geneator
    Posted: 28 Nov 2018 at 12:25pm
OK, for the gurus...
can a regular starter be used as a 'starter-generator'.
I can't see why not,providing it's wired up right but... I gotta ask !
Jay
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 1:52pm
They are on cub cadets.................
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 3:05pm
also on my B-112. I have  a lot of generators here, thought I could 'repurpose' them instead of scrapping them.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 5:08pm
 The generator on my Ditch Witch is also the starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 6:38pm
IIRR, the saying goes, all motors can generate, but not all generators can motor...
or, in simple terms, yes but only if set up right...Wink
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 8:18pm
No. The issue is, yes, it can but a starter built to just be a starter is not designed for sustained running. it will 'cook' pretty quick
I am still confident of this;
Wait for the Lord;
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 4:37pm
Generators can be but starters I would be questioning of doing it as they run on bushings not bearings - to test a generator you can motor it - on a starter they are made for high torque and intermittent draw as the field winding's  will overheat quickly
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:24pm
arrgh, I re read my post and I said it wrong...sigh..
I MEANT to say I have a lot of GENERATORS, and wondered if I could use them and 'starter-generators' like on the B-112 I have( and other graden tractors).
sigh, getting old I guess
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 6:46pm
again, Jay in theory, yes, but a generator will not have as high of torque, and will not put up with high current draw.
Wait for the Lord;
