Dr Allis
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Topic: Dr Allis
    Posted: 18 Jan 2026 at 7:30am
Question for Dr. Allis or anyone who has knowledge of this.
How do you mount an Allis #3 mower on a CA with a snap coupler,  the mower came off a CA with pin hitch.  I have found a video of some one mounting a #3 on an H farmall????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 7:34am
Sorry. Can't help you. B-C-CA tractors didn't exist in my area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 9:49am
Thanks, I have seen one now using a 3pt modification, one on a B, one on a H farmall but can't find a newer CA mounted one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 11:53am
The parts book or an operatetors manual will show the different hitches for different tractors. I'm not where I can look at the books for the #3, however I do know that on a #5 the same main hitch is used for the PinHitch and SnapCoupler tractors with a few extra straps for the SnapCoupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 1:27pm
here's the page from the parts book. Nothing is shown as different from the PinHitch to the SnapCoupler tractors. However from what I see here and knowing the differences the rivet (#4) should go through the furthest hole for the rockshaft which you will not have on a snapCoupler tractor.
  The CA PickUpPlow manual shows how to change positions of the rockshaft for lift or drawbar work. You will need to have the rockshaft in the position for drawbar work and remove the lift latches. Using the remaining hole on the rockshaft after removing the lift latches will most likely have the front of the mower too high and a PinHitch rockshaft is probably needed unless you fabricate a workaround.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 3:32pm
Paul I did email him the ca hitch pages from the manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 6:55pm
Thanks.  Just wondering what I do with my lift cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 6:56pm
The email would not open the attachments, sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 7:22am
Remove both cylinder pins from the rockshaft, let rockshaft lower all the way to vertical and re-pin lift cylinders in to other hole, as shown in many implement manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 10:04am
for some reason your emails go to spam and when I open them it tells me did not down load attachments??  Just tried the second one.  But thanks for trying,
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 10:16am
Hey that's fine. Sorry it didn't work.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 10:41am
See if this works from the manual.
Edited by mdm1 - 19 Jan 2026 at 10:46am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 10:51am
Thanks I down loaded onto my desk top, but I may have to modify some stuff, mine is a snap couple hitch so I don't have that bar that holds the draw bar, my draw bar snaps in to the coupler and has mounts under the rear end that hold up the draw bar.  I was looking at the hydraulic part, so may I assume you can turn those screws and stop flow to the cyliners for the arms.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 12:22pm
I had mine on a WD-45 with a snap coupler. Mine hook up was different than yours. If I remember I would engage the hydraulics at the quadrant and the rear cylinders would go up as far as they could then the hydraulic cylinder on the mower itself would work.  WD-45's  have two different mounts. Mine mounts on the drawbar and then to the finals. Do you have any mounting hardware at all? Good luck.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 12:45pm
Those pictures do him zero good. He has a snap couple ca.  entirely different hitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 1:29pm
No, just what you saw in the mower, my snap coupler is similar to a WD just on a smaller scale.  I can most likely make a mounting bracket.  Just wish I could see one on a CA with a snap or even a picture of a #3 on any snap coupler.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 1:49pm
Hey I just told him I would post what the manual says!!!!!! Don't know why I bother!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 1:52pm
Your post helped, especially the part on what to do with the hydraulics.  I did some google and found a picture of mounting brackets for a D-14 snap couple, which gives me at least an idea what those snap couple brackets look like.  Going to Ebay to see if there is a manual I can pick up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 3:09pm
    I guess you don't know what you are looking at.
  After seeing those pictures I will correct myself. After you remove the lift latches from the rockshaft and lower it to the vertical "drawbar" position the #3 brackets will pin into the remaining rockshaft holes and be in the correct position.
  There is no need for the drawbar cross piece to be pinned to the rockshaft and there is nothing that will need to hook into the SnapCoupler bell. If you got ALL if the pieces that came from a PinHitch CA, just lower the rockshaft and put everything in place and go mowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 3:27pm
I think we have some of those bracket part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 9:32pm
I don’t think just letting the rock shaft swing without being pinned rigid. There is too much slop and will beat the crap out of the cyl.  There has to be more to it.
