Dr Allis |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2077 |
Topic: Dr AllisPosted: Yesterday at 7:30am |
Question for Dr. Allis or anyone who has knowledge of this.
How do you mount an Allis #3 mower on a CA with a snap coupler, the mower came off a CA with pin hitch. I have found a video of some one mounting a #3 on an H farmall????
Posted: Yesterday at 7:34am |
Sorry. Can't help you. B-C-CA tractors didn't exist in my area.
Trinity45
Posted: Yesterday at 9:49am |
Thanks, I have seen one now using a 3pt modification, one on a B, one on a H farmall but can't find a newer CA mounted one.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5219 |
Posted: 22 hours 21 minutes ago at 11:53am |
The parts book or an operatetors manual will show the different hitches for different tractors. I'm not where I can look at the books for the #3, however I do know that on a #5 the same main hitch is used for the PinHitch and SnapCoupler tractors with a few extra straps for the SnapCoupler.
PaulB
Posted: 20 hours 47 minutes ago at 1:27pm |
here's the page from the parts book. Nothing is shown as different from the PinHitch to the SnapCoupler tractors. However from what I see here and knowing the differences the rivet (#4) should go through the furthest hole for the rockshaft which you will not have on a snapCoupler tractor.
The CA PickUpPlow manual shows how to change positions of the rockshaft for lift or drawbar work. You will need to have the rockshaft in the position for drawbar work and remove the lift latches. Using the remaining hole on the rockshaft after removing the lift latches will most likely have the front of the mower too high and a PinHitch rockshaft is probably needed unless you fabricate a workaround. |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2709 |
Posted: 18 hours 42 minutes ago at 3:32pm |
Paul I did email him the ca hitch pages from the manual.
Trinity45
Posted: 15 hours 19 minutes ago at 6:55pm |
Trinity45
Posted: 15 hours 18 minutes ago at 6:56pm |
The email would not open the attachments, sorry.
PaulB
Posted: 2 hours 52 minutes ago at 7:22am |
Remove both cylinder pins from the rockshaft, let rockshaft lower all the way to vertical and re-pin lift cylinders in to other hole, as shown in many implement manuals.
Trinity45
Posted: 10 minutes ago at 10:04am |
for some reason your emails go to spam and when I open them it tells me did not down load attachments?? Just tried the second one. But thanks for trying,
