Dr. Allis oil pressure max . 75lbs
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2010 at 3:05pm
I like seeing someone get beat in tractor pulling and then they go off crying,knowing the other guy is cheating more then them . Just my thought for the day.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2010 at 11:21pm
i would run a K&N oil filter on that thing, those are some stout filters
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 6:30am
Fred cry babies will always find some reason to cry. Rebuilt carb last night ran engine got it good and warm. oil pressure hot at 850 rpms is 25 psi climbs back to 75 psi at full throttle .  I believe I am ready to pull saturday .I hope to hear some crying from the other side.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 6:51am
ml,if you don't mind saying.What is the carb. off of that it has an accelerator pump on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 10:52pm
The only time Wix filters can be bought here for $3 is when the Napa store has a sale and you buy a case of them. I cut open an ordinary Fram, a Wix, and a Motorcraft (made by Purolator). Fram is poorly made. Glued cardboard ends, large pleats in the filtering media, and a stamped piece of steel for a bypass spring, no anti drainback valve. Wix uses an actual spring for the bypass. The ends of the filter are crimped metal, the pleats in the media are much closer due to there being more filtering material, a metal core so the media can't collapse, and a silicon anti drainback valve. The difference between Wix and Purolator is a stamped bypass spring VS an actual coil spring. There may be a difference in the HP series, I haven't seen the inside of one of those. If there is, and it's $8 vs about $6 for a Wix around here, Fram is charging more for the HP for what you get everyday in a Wix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 7:49am
4010 deere
