Dr Allis - 7060 Power Steering Issue
JJ_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJ_Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Dr Allis - 7060 Power Steering Issue
    Posted: 08 Nov 2010 at 10:42am
The power steering on my 7060 is awful stiff at lower engine speeds.  It feels like steering a WD with loader while something is in the bucket.  I understand it probably shouldn't steer as easy at lower rpm's but it shouldn't be this tough.  The hydraulic resevoir is full.  Not all of the time but off and on when doing field work it will have a little jerk when turning the steering wheel like it was low on fluid even though its not.
Thanks,
JJ
JJ
Polk, Ohio
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 12:33pm
90% chance flow divider is stuck on the gear pump - simple to remove just BE SURE TO PUT PARTS BACK IN LIKE THEY CAME OUT      go to www.agcopartsbooks.com enter as guest and go to part #  70265404    if that doesn't fix it tag back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 5:16pm
I concur Watson....
This page was generated in 0.211 seconds.
