Door Ajar Switch On F250 ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Door Ajar Switch On F250 ??
    Posted: 04 Aug 2020 at 4:51pm
Browsing the local O'Reilly's parts site for this switch, and there's a $20-25 variation in the switch depending if it's the "front door" or a "rear" door Confused. Yes, they are different part #'s, but what might be the difference between the front ant back doors Ouch ?? My truck only has 2 doors WinkWink. Thanks
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 10:30pm
Take the cover off the door and find the switch.  If it closes when the door is closed, pull the wires off and twist them together and tape them up.  If it's normally open then just pull the wires off and tape off the ends.
Many problems in doors are usually caused by a bad ground.  You may want to troubleshoot a little before you spend money on parts you don't need.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 10:33pm
Lotsa WD-40 on the door catch, that's where the switch is, and it's prolly just sticking..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 5:44am
I always thought a door was  a door NOT a JAR  !!!
As to WHY the fancy computer doesn't display door OPEN, is anyone's guess..
ajar and open are both 4 letter words, though not the ones I'd like to say to the 'engineers' that figure a door is a jar !
ok, if the truck was 'oil sprayed' or 'undercoated' , the waxy stuff could have migrated to the switch and 'gummed' things up....spraying brake cleaner and opening /closing the door a few times may fix it...
Jay
