Dont forget your filter
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Dont forget your filter
    Posted: 06 Dec 2025 at 3:49pm
I got a "'new to me" skid steer tractor a couple months ago.. Been fixing up a few things. Got it out to plow snow last week and it had trouble under load. Moving and dumping the bucket at the same time would kill the engine quick..  Guy told me he thought it had a governor problem.. I though maybe the hydraulic relief was stuck... Also the  choke cable was very stiff.. Today i took of the choke cable to lube it. Noted a screw on gas filter about the size of your thumb on the carb. Took it off and 90% plugged....Didnt have a new one so blew backward with the compressor and got some red "DUST" out.. (rust?)... Blew thru it with my mouth and now 90% better !!....... Put it back on and tested.. YES, its a miracle !!!  Runs great.. So much for the governor and hydraulic theory !!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2025 at 5:36pm
About month back on one cold day was having loss of power on my New Holland LX655 and would quit , then restart but no power .
Fuel Filter /water separator filter , changed out after finding one at O'Riley auto parts , now find out it's also used on Bobcat , same filter -
 Then the LX655 uses a small electric pump to boost fuel through filters , the A 300 Bobcat uses a primer bulb to lift fuel from tank to engine fuel pump through fuel filter .
This page was generated in 0.227 seconds.
