Doctor Allis Plowing near Central City Ia., spring |
Page 12> |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3963 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Apr 2025 at 6:47am |
Here's a link to the good Dr. plowing this spring. https://youtu.be/2z07n5ManPY?si=zg2noy-p8r-yZ7eV
Edited by IBWD MIke - 14 Apr 2025 at 6:48am |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1716 |
Music to my ears!
Dennis J OPKs ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: Overland Park, Points: 495 |
I remember when the 45's came out. There were numerous Allis farms in our area (Eastern NE). I was outside and heard a neighbor, probably 1/4 mile away, plowing. I know that sound and it's not a WD. Sure enough, probably the first one in our area. Spent many an hour doing that with Dad's later 45. Probably the reason my hearing is not good. No protection in those days.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21335 |
I can remember coming in the house for supper, after running 2 tanks of gas thru Dad's WD-45 plowing, and still hearing the engine in my ears !!
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4882 |
I love to watch videos like this. Whoever struck out those lands goes straighter than I do! Sounds like the Traction Booster is working.
And unfortunately, there are those who say Traction Booster wasn't any good. I'm sure there are/were some not adjusted properly. And maybe some simply not used correctly. I can guarantee if I shut mine off, the tractors land wheel was immediately scratching for traction. It was pretty obvious when I first started out that the land wheel was having a problem. It took me probably 100 ft to get her dialed in and I could then go all the way across the nearly 1/2 mile distance and never change the lever. This tractor has no fluid in the rear tires. I do hang 900 lbs of suitcase weights under the belly just ahead of the rear wheels. It helps tremendously, but still not nearly as good as 900 lbs in the rear tires themselves.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3461 |
Your video’s clock records your plow being dropped into furrow at 0:20 seconds for that pass. When you complete that plow pass, the clock reads 4:47 mins.
So that pass took 267 seconds. If pass was 2500’(2620’-120’turnrows?), then WD45’s speed averaged ~ 6.4mph? |
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4753 |
Sweet!, now that’s a field!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
I'll have to stop back sometime and set the trip odometer and see if it is or isn't nearly half a mile. Realistically I'd say traveling 4 to maybe 4.2 MPH.
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2868 |
Enjoyed the video. I'm ready for some seat time on my D 15. Thanks
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1034 |
TWO tanks of gas back-to-back!
15 gallon tank. 3.5 GPH at full load. When you got 4+ hrs run time on it (plowing) you better be heading for the house to refuel.
JPG AUSTRALIA ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 760 |
Looking and sounding good! Nice video.
Edited by AC7060IL - 14 Apr 2025 at 6:11pm |
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 7672 |
Beautiful soil.
With fields like that, and todays yields, sure wouldn’t want anything larger that 2 or 3 row corn head on a combine. Otherwise wise will have wagons parked at both ends. |
I have done some plowing and field work (nowhere near what you have done) with an Allis WD and also with a 1941 John Deere model A. The WD is significantly more powerful and will plow more in a day, but the Johnny Popper is a whole bunch more tolerable to ride and to listen to. They both have steel seats.
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 407 |
An old AC or maybe Farmall dealer video listed the acres per day their various models and tasks could take from plowing, disking, planting, chopping, to harvesting. I occasionally try finding it again but no success. It would be great to show that for antique to new tractors and equipment they handle. If you have four to six weeks to plant, say corn, a two/four/six row planter covers a lot of acres between rains and frost. More should look at seat time to debt ratio. . .
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2176 |
Very nice post. As I was watching the video and seeing the length and width of that field and see the lands set, I thought,"Doc's gonna be there a while. Hope you have some help!" Beautiful farm, dirt looks like it plowed perfect. How many acres in that field?
Leon B Mo |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5945 |
My grandfather pulled his plows through the Iowa River bottomland just north of Marengo, and from the time he quit farming, 'till the day he passed away, I'm pretty certain he was still hearing the D17 growling in his ears... Your WD sure sounds balanced on all four cylinders. I gotta pull the manifold off my Series 1 and reflatten the ports, I'm getting leakage out that #1 end (usual suspect)... but it's burning quite a bit of oil... so probably should drop in an in-frame kit and new bottom end inserts next time I pull that head...
I went back tonite and used my trip odometer to get a better feel for the length of that particular field. In these parts things are by the square mile and fields are usually 1/4 mile or 1/2 mile long etc. Well, somewhere in the last 100 yrs this farm was changed for some reason, as fence to fence it was .4 of a mile in length. Not the usual 1/2 mile that I assumed it was. When I tried to calculate the long headlands we had I think we actually plowed 1800 ft in one pass in almost 5 minutes time. That figures right at 4 MPH, which is what I thought thru gear ratios, tire size and engine speed I was probably running. The up and down hills seemed to make it farther and I guess would add to footage distance, but anyway it wasn't a full 1/2 mile as I thought from fence to fence. Regardless, it was a fun Saturday morning !!! The kingpin of the project said there was 24 acres. There were 12 tractors and plows. We started at 9 am and were done by noon. I was done with my land by 10:15 or so, and just let the others have their fun time with the rest of the field. We also had a local TV station show up and did a story on the plowing "bee" and we were on the 6 and 10 PM news Saturday night......all 44 seconds worth !! My tractor was fortunate to get some pretty good screen time during the TV spot. Again...A GOOD DAY !!
Edited by DrAllis - 14 Apr 2025 at 9:43pm |
Do you have a link to the video from the TV station or which station it was, so we can look up their website to see if we can find it?
I got it to come up just now. I'm sure they will be taking it down soon. Google: "Vintage tractors plow through time at Central City's old-time farming event" KGAN CBS2 is the channel. So, look quickly. Like I say they don't leave these posted forever it seems.
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1816 |
It amazes me to see the wonderful American Farmland with such splendor! On top of that an amazing AC tractor plowing, in perfect working order! Great video Dr. Allis!!!
~ Orangeman
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18922 |
Beautiful old tractors and plows and good friends enjoying the day and having fun! Thanks for sharing!
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2156 |
I hope I can get one of my WD45s plowing half that well!
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1273 |
It has been a long time since I heard a WD45 work all day. Last was the 4 row cultivator in the 80s.
They are on hay and wagon duty around here now. They still put in full days at some times but nothing like that plow. My dad would go out in the morning to cultivate. Lunch time was when he came back to the yard to refill the gas tank. After the second tank, it was chore time. |
A lot of us have progressed through life from the WD45 being the "big tractor" on the farm to a tractor that some people think isn't big enough to plow or do other jobs. I remember when the WD45 did the plowing, ran the chopper (either a direct-cut or one row corn head) and all the other big jobs. I remember Dad telling me the WD45 was too big to rake with and making me use the WD.
Driverdan ![]() Bronze Level ![]() ![]() Joined: 21 Feb 2015 Location: Owego,NY Points: 169 |
I really enjoyed the video !! My dad bought a WD45 new in 1955 with a 3bottom 14inch SC plow. I logged a lot of hours in that seat over the years. Great memories, thank you Doctor! ( I am 78, still on same farm and have that same tractor and still use its but haven't plowed with it in many years)
We went from a 1955 WD-45 4-bolt WF that Dad bought used in probably 1957 or 58, to a Series 4 D-17 gas in the Fall of 1967. We never had an hour meter on anything until we got the series 4. For the first 7 years of it's life it got 700 to 800 hrs a year put on it. It did EVERYTHING. When Dad bought the 200 in the Fall of 1975, the D-17 had 6,000 hrs on it. My brother still has the series 4.
Edited by DrAllis - 10 hours 45 minutes ago at 3:53pm |
Page 12> |
