Do they have fuel guages for allis chalmer b |
LiL B Orange ![]() Bronze Level ![]() ![]() Joined: 18 Feb 2025 Location: Pa Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: Yesterday at 12:51pm |
Do they have fuel gauges for allis chalmer b if they don't is it possible to install one?
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3860 |
Most common gauge is a stick about a foot long!! LOL Otherwise, I don't think I have ever seen any other type of gauge for the 'B'
Is it possible to Install an aftermarket gauge because I thought about cutting a hole in the top and install a marine 6 gal sending unit
ekjdm14 ![]() Orange Level Access ![]() Joined: 20 Aug 2024 Location: Manchester UK Points: 521 |
Anything is possible if you want to put the effort in, to be honest though I think you're best just carrying a dipstick with you & an extra 1 or 2 gallon can as a "reserve".
Just how much of a road trip are you planning, some kind of slow-paced scenic adventure? I'd likely only worry about a full on gauge if I were putting some serious miles in.
Edited by ekjdm14 - Yesterday at 1:13pm |
Not sure just alittle senic
adventure but it's dumb idea though |
LOL if you want to see dumb ideas you need to see the resurrection of my '41 B! Nothing wrong with having some fun & getting some use out of the old girl.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4867 |
The hand crank is the perfect fuel gauge. The length from the pulley spuds to the first bend is exactly the depth of the tank.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 967 |
Ha! Why didn't I think of that!
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1875 |
I don't know anything about it, only remember my grandfather had a gauge that was a gas cap for his WD Allis. It stood 3 or 4 inches above the tank. A person could get 1 of the gauges like they used on snowmobiles, ATVs and lawnmowers. You have to look down on it from above and you would have to make an adapter to go from half turn to spin on.
rtwfarm ![]() Orange Level ![]() Joined: 26 Feb 2012 Location: nebraska Points: 1298 |
Yes a aftermarket company made them for wc wd uc b and c’s
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3222 |
Could one out of a D series be adapted?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Scott B ![]() Orange Level ![]() ![]() Joined: 14 Sep 2013 Location: Kansas City Points: 1047 |
Who knew! I'll have to check this one out! I carry a cut off yard stick and mark full , half etc. Aldo gave written 1 hr, 2 hr etc to mark my burn down |
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2139 |
As Paul B said, the hand crank is the fuel gauge for a B C CA. I don't know for sure in the B C, but the hand crank sits perfectly behind the steering box bracket on the CA. But I can't remember the last time I used it to actually start either of my CA's.
Leon B MO
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 804 |
They should run all day on one tank of fuel, anyway my wd will.
Just fill er up every morning and you shouldn’t have to worry. There was a company that made gauges that you could read from the seat, I have one on a 45 gas… Doubt they’ll still in Business though.. |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4813 |
If you wanted to have an inexpensive "gauge", you could plumb a tee before the sediment bowl with a hose barb and attach a vertical piece of clear tubing to the outside of the tank. The top of the vertical tubing would have to be vented.
Edited by WF owner - 10 hours 12 minutes ago at 6:41am |
Cernunnos ![]() Silver Level ![]() ![]() Joined: 30 Jul 2014 Location: Ridgeland, WI Points: 360 |
![]() Here is a gauge I saw on a CA last year. However, I can't recall what company made it. It was similar to an older gas gauge on a snowmobile . It measures in 1/4 increments I believe.
Here’s the one on my 45..
AveryD12 ![]() Bronze Level ![]() ![]() Joined: 05 Mar 2018 Location: Foxworth.MS Points: 103 |
Wbecker had a post on Nov 23, 2016.
“Fuel gauge on my b gas tank”. He did an awesome job. |
I’m not sure how to post a link. I will try to post a screenshot
John426 ![]() Silver Level ![]() Joined: 14 Aug 2012 Location: France Points: 302 |
