Do these pins look worn?
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Do these pins look worn?
    Posted: 16 Nov 2010 at 6:21am
Just looking over the variable speed on my M, and was wondering if these pins look worn.  Is it rebuildable?  Thanksuploads/2039/Gleaner_M_Combine_Photos_Nov10_004.jpg
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 8:15am
They look pretty worn to me.  It's easy to replace them by screwing them out and screwing the new ones in.  Use some thread lock on the new ones....
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 10:39am
Thanks, NEJim!  You are confirming what I thought.  There doesn't seem to be any noise from them at all, but I thought they were looking worn.  Take care.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 9:38pm
Also check the bushings in the sheave, if they get too bad will vibrate and wear the shaft, experince speaking.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 11:02pm
Replace pins and bushings and it will last longer than you.If you are a real "tight wad" you can drive the bushings out and turn them 180 deg to have original new wear surface.These only wear on "load" side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 5:47am
Hey guys, can this all be done with everything still on the combine, or should it be taken apart.   I may take it all apart sometime, and replace the big bearing on the cross shaft, just for insurance.  It is easier to change now, than in the field in August!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 8:11am
Kevin, it's not bad at all to take apart.  As long as you are into it, bearing replacement is probably a good idea.  Then it's all new and good for several years.
