Do I need a new truck, or do I want one?
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Do I need a new truck, or do I want one?
    Posted: 23 Mar 2019 at 8:58pm
I have a 2007 half ton 2wd GMC Sierra with a 4.3 V6. The first new truck I ever bought. When I got it, the only thing I wanted to pull was a bass boat. It's still a great truck and does 90% of what I need it to do. There are times when I need more towing power. Especially this time of year when I'm fertilizing. Two ton is a big load for this truck. I pulled this spreader with 4500 lbs. of fertilize.
Only 9000 lbs. this year so two trips wasn't that bad, it usually takes more. They are other times as well. I can't pull a trailer big enough to haul the D-10 and B at the same time. I have traction issues at times too. My truck can get stuck on wet grass. But I always make do, and figure out a way to get the work done. After all, my Father never had a heavy duty truck. I'm farming the same farm, so why do I need one? It must be want, I don't think I can justify paying 70k for a 3/4 ton 4WD just yet.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:14pm
If it were me, I’d stick with what you’ve got. Dad had a ‘09 and we really liked it. The new ones are nice, but unless I *had* to have one, I’d stick with the ‘07.
I guess to sum it up in Shameless’s words, “I’m cheap!”
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:16pm
I worked for a fertilizer company for years, the same company had 4 stores in 4 different towns, each store had a 3/4 ton 2-wd pickup and the rest were 1/2 ton 2-wd pickups. I see that what you are trying to pull is on;y a one axle trailer, find a company that uses 2 axle spreaders and they will pull a lot better. one year our company bought all new ferd 3/4 tons and they didn't have any better suspension than the 1/2 tons. I pulled a lot of weight with 1/2 tons, some 4x4 and some 2-wd. the 4x4 was only used for help in hooking up in the fields or the uneven surfaces we delivered at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:24pm
Brother shows up with a 2019 Expedition, tags out at $104K CDN bux ! Nice, well I liked the seats...split  adjustable, heated, coled, 5 zone massage....TONS of computers and electronics to go wrong ($$$$!!!!). OK, it's not his, just a loaner from Ford as he testdrives/write in mags about vehicles. To replace my '97 F150 would be $42K.+15% taxes..... coins I don't want to waste. Easier to spend $1K /per year until the grimreaper comes for me. For the times you NEED a bigger ride, ask a fellow farmer or friend. I know you can't rent any truck up here with a hitch !
better to be' penny wise and NOT pound foolish'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:28pm
I did forget the mention above, that all our trucks we used for pulling were about shot after 3 years time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 7:26am
Buy a used 3/4 ton , 2013-2015 can be found for a lot less than new .I have been keeping my eyes open for one as my 2005 is starting to show its age .I will not be paying 70 grand for a new truck but looks like I will be spending 25 to 30 grand for a used one . Hopefully I can find one that was well taken care of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:12am
Shameless,
This company has nice newer spreaders with two axles. I usually try to get one, but they were all out. The spreader in the pic actually broke down with me, with half my fertilize still on it. I ended up having to settle for a smaller ground driven unit with a manual lever. I didn't care for that thing, but I got the fertilize on the ground.
You all make good points. That's kind of the way I felt too. Unless my farming operation gets bigger, I'm going to hold off buying a truck. Although, I will probably keep wanting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:33am
Ranse,
 Its probably a want thing more than a need thing. But I traded up to a used F250 and paid about half what a new one costs. I like the truck and it does a great job hauling a ton of water in the bed or the D17 on the gooseneck. We arent getting any younger. Got to have some toys before we check out. Also you need a nice ride to drive up here and fish for lake runs and walleyes!:)
Yea my dad made it with a 2 wheel drive also! I dont remember him getting stuck either.
This page was generated in 0.230 seconds.
