Do 125ci sleeves fit in a 116ci B motor?
JR Maley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Topic: Do 125ci sleeves fit in a 116ci B motor?
    Posted: 11 Jan 2011 at 3:50pm
Do 125ci sleeves fit in a 116ci B motor?  What is needed to go to 125 or larger in a hand crank start B?  I would like to keep the compression ration around the same for easy starting.
-JR
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:04pm
gee, all b's except the early Wakeshau B's had 125 CI engines 3 3/8" bore   3.5" stroke
right?
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:23pm
The early ones had a 115 CI engine then the 125
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:28pm
The BE engines were 116 cu. in. with 3 1/4" bore.    Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:37pm
the original BE was a 3-1/4 inch bore. Later the same block was fitted with bigger ID sleeves to get 3-3/8 inc bore. Same rods, valves, crank, block... they all have interchangable parts.  Most aftermarket kits are now 3-7/16 bore and will go into the BE or the CE block. Compression is probalby 6 or 6.5 to 1 on most kits.
JIminArkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JIminArkansas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 7:26pm
When did the 3-7/16" overbore kit come out for use? I have an old B from a fence row find and it has the larger overbore pistons in it. It was stuck but a little gasoline in each hole and a match and it was free. Took longer to take the head off than to get it unstuck.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 9:34pm
All you need are the sleeves, pistons and "O" rings.
Nothing major to do. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:01pm
Thats a good question  Jim. I always thought it had something to do with Allis going out of buisness and most aftermarket parts being made overseas after that.. I dont have a clue to the answer, but will guess mid 1980s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 11:25pm
I have a 1957 Tractor Supply Blue book that shows the 3 7/16 overbore kit for the B, C, CA, and RC.  That was about the time the power race started.
This page was generated in 0.073 seconds.
