DJ on tht Swamp Cooler
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: DJ on tht Swamp Cooler
    Posted: 18 Jul 2019 at 11:02am
I have an uninsulated 40Xpole barn.  A barn cat (refuses to be domesticated and getting old) dwells in there.  It is getting to 100/100+ even with two fans (one in and one out) running.  I have the cat in the house in a kennel for the ongoing heat wave.
Anyhoo you mentioned snuggling up to a swamp cooler.  You think with one of the portable ones in there it would generate some cool air floor along the cement floor?  Worthwhile for ole Midnight?
I would be interested in your thoughts and anyone else on this issue.  I just have not sprung since worthless investments just pizz me off.
Maybe on needy occasions I could have that thing blowing on my big bottom.  Confused
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 11:45am
 Hey Dave,,it good to hear from you,,it's been a long time and time does fly by so fast anymore,,,
 Yes,, I cabbaged on to this good sized swamp cooler (uses 36" pads) some years back,,think I gave $20 for it with a good 1/4 horse motor. One of the pillow block bearings on squirell cage had started to freeze up but after some oilin,,it freed up good. I made a frame work out of old 1 1/2" bed rails I picked up at the City dump and added 4 small caster wheels at the corners so I can roll it around in garage and carport, should work good on your concrete floor. Not sure what the CFM is but I can feel the cool air from bout 20 feet away even in this hot dry country,,,,I have to re-fill with water bout every 2 hours in this heat but that ain't no biggie. Your Kitty-cat should love one of these,,,and,,,,and,,,you will too,,,!!!Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 11:47am
 Hey Dave,,,check out the MarketPlace,,I see lots of these swamp coolers for sale almost new for $50 or less or the yard sales too,,,,
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 5:16pm
If it's not hot and "DRY", the last thing you want is a swamp cooler.
And if you use it inside, any metal around will start to rust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:52pm
They work best in low humidity but even in this sweltering GA heat they help. Never used a portable unit but worked on a lot of roof mounted ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 1:54pm
old vehicle radiator, a box fan, and a garden hose....
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 5:17pm
 Well,,I do declare,,,Shameless,,,you is beginnin to sound like ole Skinflint Joe,,,,,thas the kind of outfit I used to have ,,,,til I moved up to this roll around model,,,I feel like i'm chittin in tall cotton with this shadetree model,,,,WinkWink
This page was generated in 5.229 seconds.
