DJ on tht Swamp Cooler |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: DJ on tht Swamp CoolerPosted: 18 Jul 2019 at 11:02am |
I have an uninsulated 40Xpole barn. A barn cat (refuses to be domesticated and getting old) dwells in there. It is getting to 100/100+ even with two fans (one in and one out) running. I have the cat in the house in a kennel for the ongoing heat wave. Anyhoo you mentioned snuggling up to a swamp cooler. You think with one of the portable ones in there it would generate some cool air floor along the cement floor? Worthwhile for ole Midnight? I would be interested in your thoughts and anyone else on this issue. I just have not sprung since worthless investments just pizz me off. Maybe on needy occasions I could have that thing blowing on my big bottom.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 18 Jul 2019 at 11:45am |
Hey Dave,,it good to hear from you,,it's been a long time and time does fly by so fast anymore,,, Yes,, I cabbaged on to this good sized swamp cooler (uses 36" pads) some years back,,think I gave $20 for it with a good 1/4 horse motor. One of the pillow block bearings on squirell cage had started to freeze up but after some oilin,,it freed up good. I made a frame work out of old 1 1/2" bed rails I picked up at the City dump and added 4 small caster wheels at the corners so I can roll it around in garage and carport, should work good on your concrete floor. Not sure what the CFM is but I can feel the cool air from bout 20 feet away even in this hot dry country,,,,I have to re-fill with water bout every 2 hours in this heat but that ain't no biggie. Your Kitty-cat should love one of these,,,and,,,,and,,,you will too,,,!!! ![]() |
desertjoe
Posted: 18 Jul 2019 at 11:47am |
Hey Dave,,,check out the MarketPlace,,I see lots of these swamp coolers for sale almost new for $50 or less or the yard sales too,,,,
cabinhollow
Posted: 18 Jul 2019 at 5:16pm |
If it's not hot and "DRY", the last thing you want is a swamp cooler.
And if you use it inside, any metal around will start to rust. |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 18 Jul 2019 at 8:52pm |
They work best in low humidity but even in this sweltering GA heat they help. Never used a portable unit but worked on a lot of roof mounted ones.
shameless dude
Posted: 19 Jul 2019 at 1:54pm |
old vehicle radiator, a box fan, and a garden hose....
desertjoe
Posted: 19 Jul 2019 at 5:17pm |
Well,,I do declare,,,Shameless,,,you is beginnin to sound like ole Skinflint Joe,,,,,thas the kind of outfit I used to have ,,,,til I moved up to this roll around model,,,I feel like i'm chittin in tall cotton with this shadetree model,,,,
