DIY plywood laminated beam
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: DIY plywood laminated beam
    Posted: 11 hours 58 minutes ago at 6:48am
I have been kicking around the idea of building a couple 'foamy' campers.
Most are built strictly out of foam, but would like a little more structure without adding a lot of weight. For reference, I am thinking something like the Tusca brand slide-in camper.
I am wanting to make wall studs and rafter one piece. Back in high school shop class we built a couple storage sheds, and used a reddish brown glue to glue the plywood gussets to the rafters, but don't remember what it was. I seem to recall it was a powder mixed with water. Does anyone know what that might have been?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 51 minutes ago at 7:55am
I don't know what you used, but a few years ago, a friend, who is a contractor, recommended that I use Loctite PL Premium (caulking gun tube) on a project (laminating 2x6 for a pole building).
He said it was the best construction adhesive he ever used. He showed me some wood that he had glued in the past and later tore down. The wood broke, but the glued pieces were still adhering.
It's quite inexpensive, easy to find (our local lumber yard carries it) and easy to use.
Edited by WF owner - 10 hours 50 minutes ago at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 55 minutes ago at 8:51am
i personally prefer something that says GLUE instead of ADHESIVE...
AI Overview
Titebond III Ultatime Wood Glue
 is the top choice for a 1-part, ANSI/HPVA Type I waterproof glue, ideal for interior/exterior use, cutting boards, and high-strength, water-based cleanup. Other excellent, durable options include Gorilla Ultimate Wood Glue and Titebond II (water-resistant).
Edited by steve(ill) - 9 hours 53 minutes ago at 8:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 11 minutes ago at 3:35pm
I'd second the TB3, it's a lot less messy than the gorilla glue.  And if you use GG, don't get it in yo fro:
This page was generated in 0.383 seconds.
