DIY plywood laminated beam
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: DIY plywood laminated beam
    Posted: 07 Mar 2026 at 6:48am
I have been kicking around the idea of building a couple 'foamy' campers.
Most are built strictly out of foam, but would like a little more structure without adding a lot of weight. For reference, I am thinking something like the Tusca brand slide-in camper.
I am wanting to make wall studs and rafter one piece. Back in high school shop class we built a couple storage sheds, and used a reddish brown glue to glue the plywood gussets to the rafters, but don't remember what it was. I seem to recall it was a powder mixed with water. Does anyone know what that might have been?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 7:55am
I don't know what you used, but a few years ago, a friend, who is a contractor, recommended that I use Loctite PL Premium (caulking gun tube) on a project (laminating 2x6 for a pole building).
He said it was the best construction adhesive he ever used. He showed me some wood that he had glued in the past and later tore down. The wood broke, but the glued pieces were still adhering.
It's quite inexpensive, easy to find (our local lumber yard carries it) and easy to use.
Edited by WF owner - 07 Mar 2026 at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 8:51am
i personally prefer something that says GLUE instead of ADHESIVE...
AI Overview
Titebond III Ultatime Wood Glue
 is the top choice for a 1-part, ANSI/HPVA Type I waterproof glue, ideal for interior/exterior use, cutting boards, and high-strength, water-based cleanup. Other excellent, durable options include Gorilla Ultimate Wood Glue and Titebond II (water-resistant).
Edited by steve(ill) - 07 Mar 2026 at 8:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 3:35pm
I'd second the TB3, it's a lot less messy than the gorilla glue.  And if you use GG, don't get it in yo fro:
Riprock View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riprock Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 6:22pm
I remember using weldwood brand that was a brown powder.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 7:37pm
Need a glue / adhesive that will not react with foam as some will dissolve foam and make it achier .
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 8:52pm
Be careful with gorilla glue as some of their formulations foam up, becoming both unsightly and weaker.
If both parts are wood then use Titebond 3 for possible damp or wet environments. Titebond 2 is popular with guitar builders, super strong but removable/repairable with steam heat to reset necks. Titebond 3 won't be repairable that way, but perfect for what you want.
Make test pieces you can test whatever you want to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 10:20pm
Thanks Riprock. I think you're on the right track.
