Distro Tach Drive Gear
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: Distro Tach Drive Gear
    Posted: 01 Mar 2026 at 8:21pm
Finally got around to hooking my tach drive cable up, but it don't spin. When I put the cable into the distro I can't get anything to move. So it's like frozen solid.
Does anybody know where I can get one of those gears? Is it likely to be just that gear or is the drive gear on the distro bad too? Anything else that could be bad I don't know about?
Anybody have cool tricks to get that spanner/nut "tachometer coupling" off?
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2026 at 9:19am
Is this on a gas 262 engine? If so, gears are bad on distributor shaft (someone didn't grease). Will need to replace shaft - good luck finding one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2026 at 4:02pm
I forgot to say what tractor! 190XT G2800 engine. The 301.
Edited by MadCow - 03 Mar 2026 at 4:03pm
