Distributor ?
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: Distributor ?
    Posted: 23 May 2020 at 4:52pm
Can a moron rebuild a Delco distributor from a G? I bought the new bushing kit. How do you get the shaft out? Oh by the way I'm an electrical moron. TIA.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 7:05pm
Haven't worked on a G but all distributors I've seen have a pin holding the gear on. Once the pin is removed you have to press the gear off. Once the gear is off the shaft will slide out the top.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 8:46pm
Be sure to remove any burrs on the shaft and around the hole in the shaft.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 9:37pm
.We did them when I was in trade school in 1980. I do remember the shaft seizing as you tried to pull it out, but most of those distributors had an aluminum body. Rotate the shaft and work it around with some wd40 to break down the varnish that makes it bind.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 9:57pm
Yes, a moron CAN rebuild a distributor... we do them all the time...  ;-)
