Distributor rebuild questions
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: Distributor rebuild questions
    Posted: 4 hours 41 minutes ago at 6:41am
I'm cleaning up/rebuilding the Delco distributor 1111 735 on my CA 125 engine. The springs and weights seem to be in good condition, the bushing to shaft is tight does not wiggle at all. What should the vertical end play be? With the distributor out of the tractor using a filler gauge I'm getting about .012 between the gear and the housing.
Anything else I should be concerned with checking?
The gear itself does seem to have some where, are new distributor gears available if needed?
Thanks
