Distributor housing oil tube
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Topic: Distributor housing oil tube
    Posted: 23 Jul 2010 at 2:13pm
Looking at other "B's" and the It manual I believe I am missing an oil tube which should run from the governor housing to the Distributor housing.  (1949B).  Anyone know if this is the case?  If so, where on the dist housing does the line attach? Thanks!!!
Bob, North Carolina
1949 B
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 2:24pm
in 1953, they put the Tee fitting on the oil line to the governor. I do not have a B that new, so I am at a loss to tell you where it hooks up. Before 1953, the oil line only went straight into the governor.
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 3:35pm
Bee, on my '48 B the oil line runs from a fitting at the back of the block near the oil filter directly to the governor housing as in the front part of your B.  Where does that line go on your B?
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 4:01pm
My line runs from the oil pump to the governor.  There is also a hole from the governor section to the distributor section.  From what I have read this hole is described as a "drain" hole which led me to believe I should have a feed line off a tee as Glen described.  Must be the design was changed after my 1949 was built.
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 3:29pm
My 48'B had the oil line coming off the Tee block in the cylinder head, down the side of the valve cover to where the  Govenor bellcrank pivots for the throttle linkage. I offer a new kit for that oil line if interested with the fittings.......
Steve@B&B
Jt s. candycane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jt s. candycane Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 3:29pm
You still selk that kit I need one
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 3:49pm
Jt... this is STEVES site... check it out..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 5:24pm
What you have is the "DELCO" aftermarket conversion kit that replaces the magneto. That was NOT an Allis Chalmers part.  That set up does NOT have the distributor oil line as the OEM distributor uses.
I would think the "Jersey wiring expert" would know this and would have mentioned it in his post..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:29pm
Sorry Paul, but if you were observant, you would see that post I made was from 2010 not to this recent post. Nice try, but I haven't been on here in a while...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 6:51am
Steve@B&B
 Time is of no relevance to facts.
This page was generated in 0.131 seconds.
