distributer d17 series 1 |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Topic: distributer d17 series 1Posted: 10 Aug 2023 at 10:34am |
will i be able to use the govenor and the distributer and the lube system in the wd block i am going to go get a tractor with a rod hanging out the pan on saturday hopefully the head will be good, (rebiuldable) for the puller engine
Posted: 11 Aug 2023 at 8:15pm |
It will all fit, but be concerned about gear lash being too tight or too loose. That is why there is an alignment pin drilled into the block mounting surface.
HudCo
Posted: 12 Aug 2023 at 10:14pm |
got it home tonight looks like i will still need to find a distributer drive this has the steering pump in between iwont be useing thaton the 37 wc
