disc options pre D series |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3295 |
Topic: disc options pre D seriesPosted: 3 hours 17 minutes ago at 10:16pm |
Started this instead of hijacking another thread.
It seems like whenever someone posts about a snap coupler disc to knock down plowed ground, people immediately say you need a heavier disc. Well then, what were the options? What discs were available when the B, C and W series were new? I'll admit I don't know a lot about the B or C series, but, weren't they meant to be the do everything tractor for the small farmer that could probably only afford one tractor? What was available from Allis Chalmers as a "heavy disc" for them? Weren't they marketed as a set? You bought a tractor, a plow, a disc and either a drill or planter? Most of what I've seen, it was a mounted disc. If the snap coupler mounted disc wasn't meant to knock down plowed ground, what was it meant for? |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8761 |
Posted: 2 hours 43 minutes ago at 10:50pm |
We always dragged plowed ground with a 3 section harrow,broadcast fertilizer and disc it in then one more pass with the harrow,then plant. Spring plowing and the disc wasn't buried. This was with a WD. Old days weren't for sissys.
These days I sit in a climate controlled 8070 and rip it up in the fall with a 9 shank disc chisel. Usually 2 passes in the spring with a field cultivator and plant. I'm 30 yrs behind the times but it works for me. Dad started out with an Oliver 8ft drag disc....the kind that you set straight to travel.
Edited by SteveM C/IL - 2 hours 29 minutes ago at 11:04pm |
