disc options pre D series
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: disc options pre D series
    Posted: 28 Dec 2025 at 10:16pm
Started this instead of hijacking another thread.
It seems like whenever someone posts about a snap coupler disc to knock down plowed ground, people immediately say you need a heavier disc. Well then, what were the options? What discs were available when the B, C and W series were new? I'll admit I don't know a lot about the B or C series, but, weren't they meant to be the do everything tractor for the small farmer that could probably only afford one tractor? What was available from Allis Chalmers as a "heavy disc" for them?
Weren't they marketed as a set? You bought a tractor, a plow, a disc and either a drill or planter? Most of what I've seen, it was a mounted disc.
If the snap coupler mounted disc wasn't meant to knock down plowed ground, what was it meant for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 10:50pm
We always dragged plowed ground with a 3 section harrow,broadcast fertilizer and disc it in then one more pass with the harrow,then plant. Spring plowing and the disc wasn't buried. This was with a WD. Old days weren't for sissys.
These days I sit in a climate controlled 8070 and rip it up in the fall with a 9 shank disc chisel. Usually 2 passes in the spring with a field cultivator and plant. I'm 30 yrs behind the times but it works for me.
Dad started out with an Oliver 8ft drag disc....the kind that you set straight to travel.
Edited by SteveM C/IL - 28 Dec 2025 at 11:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 4:19am
You have to remember that B's started a tractor revolution.  It was meant and marketed to farmers being weaned from the horse.  Horses didn't do well with a heavy disc harrow, and the whole small farming culture was plow, drag harrow, cultivate several directions, harvest...  Now if you had a bigger tractor, you might buy a #30 or 40 lift type disc, for say a W series tractor, all of this was sort of in its infancy, late depression and through WW2.  It took getting through the depression, and war, before the manufacturing and economy, was ready for mounted equipment to be  introduced and produced...Wink
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 5:53am
One of our neighbors had, what they called, a set of AC Snap Coupler bog harrows. If I remember correctly, they had large discs, maybe in the 20" or bigger range. I think they were only about 6' wide.
When I was a teenager (late 60's), Dad borrowed them. He sent me to pick them up with the WD45. I knew the discs were heavy, but when I drove across the railroad tracks, the front wheels came in the air, and the discs touched the ground.
I've never seen another set of discs like them.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:09am
My grandfather said sometimes the rear tires of the tractor were more effective at breaking up plowed ground than the disk
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:27am
You might be confusing this with guys trying to talk about disking UNPLOWED ground with these little disks.
They work well in ground that has already been plowed, but they won't do anything to try to disk unworked ground.
In The 70's as tractors got bigger they started coming out with heavier disks on 9" blade spacing. These typically disk up unplowed ground just fine.
So sometimes guys think they can do the same thing with the little light disks on 7.5 spacing, but they aren't heavy enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:28am
Three trips before planting. First trip with the disc the way the plow furrows laid. Second trip also with the disc at an angle to the first trip. Third trip with a 4-section harrow at another slight angle to make planter marks easy to see.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:36am
[QUOTE=WF owner]One of our neighbors had, what they called, a set of AC Snap Coupler bog harrows. If I remember correctly, they had large discs, maybe in the 20" or bigger range. I think they were only about 6' wide.
[/QUOTE
Seems that bog harrows were more common in the South,used to be an auction in NC with AC equipment about always had a bog harrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 6:39am
Nope, not confused. Started this post because of comments in Pointer Hollow Farms post. But have seen it before in other posts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 7:51am
I have a #20 disc that I use behind a CA. I think the problem that most are having with poor results when using the #20 disc harrows is: they are not working the ground under proper conditions. With NO-TILL having been around nearly my entire lifetime, those that are younger don't have experience with plowing and working ground and what the proper conditions should be.
  With my # 20 disc I have a utility pole hooked to the back that is a bit wider than the disc and with plowed ground that isn't too wet it will knock it down level with a single pass. My disc is a 8' model with 28 blades that are 16", with  a 7" spacing and scalloped blades on the front gangs. This disc doesn't do much in unplowed ground. it will do OK when following the coil spring tooth field cultivator I have.
  Now for wet ground I have a #40 disc that will mix water into a pull track very efficiently. My #40 is 6' and has 16 22" scalloped blades on a 9" spacing and will do fair in unplowed ground that isn't too dry and hard. It is really too aggressive as it's set for plowed ground. The angle on the #40 is adjustable and with the angle lessened it would do better in plowed ground.
  Bigger newer discs that are heavier for larger tractors tend to ridge ground because those using them want to go too fast.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 11:34am
Regional differences.......................Beer Hopefully we can all leave as friends.
I made a living farming small grain and grain hay. i have never pulled a plow. Don't know anybody that owned a plow. The offset disc 9 inch spacing was the only tillage tool some owned. Most had a spring tooth cultivator of some kind. By the 60's 12 inch spaced discs with 32 inch blade could be found.
Killefer, Dyer, Goble, Towner all based in California back in the early 1900's. All had a 9 inch spaced disc as one of their main tillage tools. Taken over by JD, IH, and MF, Towner remained independent until they faded away about 2000 or a bit before. But tillage was done with crawlers, even on tabletop level vegetable fields, until the 4x4's showed up.
It would be interesting how far east any of these companies got before the 1960's when they had been taken over by bigger companies. So there have been choices from way back if you looked really hard.
Sorry for butting into a Midwest to east coast topic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 9:53am
Thanks guys. You have confirmed my thoughts. Multiple passes were made. Like Steve said, old days weren't for sissys. And like Ray said, it depends on your soil.
Back in the days when these discs were used, most farms (at least in my area) were only 1 or 2 quarters. And not all of that was tilled.
My thoughts on people saying you have to have a heavier disc comes from the mentality of the Big Time Operators that everything has to be one pass and done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 2:48pm
Back in the 50s and early 60s when corn populations were about 1/3rd of what they are now, and everyone was still on 38" rows, a good sharp drag type disc (no wheels) would work the ground well enought to be able to seed oats, which was normally what followed corn. because almost everyone used oats as a cover crop to start alfalfa for their dairy herd. Then the drag type discs were adequate.  I have three #9 discs , they were the lighter discs and worked well in plowed ground, and one #11 disc which is heavier and worked up corn stalks better that the #9s.  The snap coupler fully mounted discs on the WD did about the same job as the #11 drag disc in stalks.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 3:05pm
In the time these disc were used the corn  plant population was much lower and the  Stalk was not GMO.   BT
  much tougher fiber in stalk
Edited by Marlyn nwia - 30 Dec 2025 at 3:09pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 4:06pm
You know, another important point is if you plow too wet or with incorrectly set plow, you are going to make it a lot harder to disk effectively. Also i think soils tended to be more healthy. I bet organic matter was higher and compaction was less. Too many guys think corn then soybeans and back to corn is a crop rotation.
This page was generated in 0.120 seconds.
