Disc ID |
MBolton
Topic: Disc IDPosted: 03 Jan 2011 at 1:56pm |
Here are photos of my disc
MBolton
Posted: 03 Jan 2011 at 1:58pm |
I meant to say "lever" not level!
KenB
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24893 |
Posted: 03 Jan 2011 at 2:53pm |
I've got the front 'section' just like yours so I'd like to know too !
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1185 |
Posted: 04 Jan 2011 at 8:43am |
Bump
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2724 |
Posted: 04 Jan 2011 at 1:59pm |
From what little I know, I believe it's a #8 disc. I had a #10 disc and donated it to Dale's museum in Paris, IL. The #10 was a little wider and heavier. The present position it is in is considered "transport" mode so you could pull it around the barnyard (or gravel road) without doing much damage. To get the gangs to pivot forward and backward you need to pull up on the levers (toward the front of each tongue). If you do this when hooked up to the tractor, then all you have to do is either drive ahead (or back up depending on whether you're moving the front or back gang) and the framework will move to allow for pitching the gangs forward/back for fieldwork. Hope this helps.
Brian F(IL)
KenBWisc
Posted: 05 Jan 2011 at 9:23am |
Thanks Brian!
KenB |
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 05 Jan 2011 at 10:41am |
I believe that the disc models were 8, 9, and 10 respectively, The one I had was a No. 9
CTuckerNWIL
Posted: 05 Jan 2011 at 11:06am |
I have a 6 foot disc just like that, Dad got new with the 47C he first had.. Other than setting the angle of the gangs, the only other adjustment is how many cement blocks(or field rocks) you put in the tray. Charlie
BrettPhillips
Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Posted: 07 Jan 2011 at 9:37am |
The disc in the picture is a 6 ft. #9. Looks to be a pre 1950 model, since it has the spring loaded scrapers. Later ones had one piece scrapers.
