dip-stick
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: dip-stick
    Posted: 01 May 2024 at 9:01pm
Oh! no ; Because the bell shaped  retainer on the engine dip-stick of my D 17 IV was detached and lost; I had replaced it with a new one from my Agco dealer.  Today a very competent experienced mechanic withdrew the dip-stick and behold!  the dip-stick had broken  approximately three inches below the retainer.  What happened? Need we remove the engine oil pan and remove the broken pieces?
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 9:45pm
It takes quite a bit of work to remove the oil pan on a D17-IV. If it were mine, i would pop the drain plug and try fishing around with a flexible magnet first. You may get lucky enough to drag the broken piece of the dipstick out the drain hole and not have to go through all the extra work of pulling the starter, front sheet metal, front axle, radiator, front support, power steering lines, etc just to be able to remove the pan. The oil pump pickup tube has a screen and metal shield on it, so unlikely that any dipstick material would be sucked up. Give the magnetic pickup tool a try, might just get lucky. In all honesty, the remaining piece of dipstick probably wouldn’t hurt anything if left at the bottom of the pan. I would want it out of there, though, if it were my tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:01am
It can't do any harm just laying in the pan. It can't get through the screen and I seriously doubt it can even get drawn up off the bottom to begin with. Not worth the effort to remove the pan in my world. If you could find it with bailing wire and a magnet, the pickup likely in the way to get it in position to get out.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 4:07pm
If you don’t own a mechanics shirt pocket telescoping pen style magnet, maybe go buy one? Some extent 24”?
Use it to enter the dipstick tube & fish out broken dipstick that way. Chances are; the dipstick pieces may still be resting inside dipstick tube?
Edited by AC7060IL - 02 May 2024 at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 5:06pm
Good point about it still being in the tube. Will depend how long it is and if the tube ends close enough to the pan to keep it from sliding out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:24pm
Next time you change the oil, shove a cow magnet up in the drain plug hole and leave it in there laying on the bottom of the oil pan.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 9:21pm
dr. no one know what a cow magnet is any more  they kind of whent with the big dairy buyout in the early eighties
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 3:33am
I am a former and an"old" dairyman; I know what it is used for and how to use it.👍👍
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 8:07am
A Borescope inspection camera will allow you to look inside the oil pan.
These cameras are great for inspecting engine cylinders and lots of other things, with minimal disassembly.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 10:15am
Smallest borescope I see is 5.5mm, that might work.  Use of a magnet to try and pick it up, will only result in the magnet frustratingly sticking to everything else on its way in there, IMHO.  If it's not still inside the dipstick tube, I'd leave it.  Those cow magnets are too big to get into drain plug hole, aren't they?
Edited by GSTROM99 - 04 May 2024 at 10:18am
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 6:51am
You might try to apply a strong magnet to the outside of the oilpan.  Once you "trap" the dipstick piece you might be able to slide the magnet over towards the drain hole, where you should be able to grab it with some needlenose or something.  Might take a few tries, but I would imagine you can coax it over towards the hole that way.
