Different way to pump tires! |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Topic: Different way to pump tires!Posted: 16 Dec 2019 at 7:03pm |
https://lacrosse.craigslist.org/grd/d/tomah-antique-collectable-tractor-tire/7029836122.html Never have seen anything like this before. Were these common?
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 16 Dec 2019 at 7:07pm |
Antique and collectible...........he should be asking a lot more. IRRC those tire inflators are still available. Would come in handy of some of the older equipment.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3980 |
Posted: 16 Dec 2019 at 7:40pm |
I've got a couple of those around here somewhere. Haven't used one for a long time.
HaroldOmaha
Posted: 16 Dec 2019 at 8:24pm |
I had an IH air hose with 4 different adapters one time. used it with my 53 Ford
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 16 Dec 2019 at 9:04pm |
I remember those. Dad had one because we did not have an air compressor. I have always wondered or thought you were creating an explosive tire with the gas fumes going in.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 16 Dec 2019 at 9:27pm |
I had a JD pump, mounted on PTO.
I might have it still, cant recall where I stored it. A neighbor had one, kept it on his rake tractor while custom baling for us and others. |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 16 Dec 2019 at 9:28pm |
Those had flapper valves in them, they drew in fresh air into the cylinder, not threw the carburetor, and then pushed it into the tire.
Dusty
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 16 Dec 2019 at 11:11pm |
They weren't just found in tractors- they were commonly found in the trunk of just about anything from a 29 Ford A on up to the mid '60's...
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 16 Dec 2019 at 11:54pm |
The one my neighbor had used the air going through the carb, worked ok but you got the gas in the tube too which wasn't good for the life of the tube.
Allis Express participant |
john(MI)
Posted: 17 Dec 2019 at 12:19am |
I've used one, it was probably 1969, on the farm to air up a tire. I guess I shoulda mentioned that I used it with a WD45 to air up tires.
Edited by john(MI) - 18 Dec 2019 at 1:04am |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 17 Dec 2019 at 5:00am |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25547 |
Posted: 17 Dec 2019 at 5:24am |
I assume the valves were in the piston |
I am still confident of this;
marion
Posted: 17 Dec 2019 at 6:51am |
had a boy work for me in the 80's, drove a late 60's ford, Tires were in so bad shape he left the thing plugged into one cylinder and would air all tires up at night when time to go home
ford8nwd
Posted: 17 Dec 2019 at 8:11am |
I also had a JD PTO pump, worked well, but very slow.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 17 Dec 2019 at 10:48am |
Had not thought of that method of filling tires in years. The adapter and hose where under the seat in the pickup at all times. I don't remember dad ever having hand pump to fill tires. I am sure the one here had 2 or 3 different thread sizes to fit any spark plug size they had back in the day.
Anyone here with more than a big lot in town that does not have a air compresser today?Many of us have 2 or more. The first compresser on the ranch showed up right after the gooseneck stock trailer. Dad had away of getting around out in the hills without 4 wheel drive.
That was a waste of money in his eyes. But one of his tricks was letting air out of the rear tire to were they had a big bulge. So the compresser was a big help to get the 15 psi back to 60 to haul 10 cows. |
DougG
Posted: 17 Dec 2019 at 11:14am |
Marion,, just my opinion, but if you had the money to pay him , surely you could've helped him with tires,,
Greg (Hillsboro, OH)
Joined: 11 Sep 2009 Location: Hillsboro, OH Points: 1198 |
Posted: 17 Dec 2019 at 11:32am |
like Festus, we had one as we didn't have a compressor either. They did work pretty well.
Unit3
Posted: 19 Dec 2019 at 11:30am |
We have a JD as well. Used it once. That's enough.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 19 Dec 2019 at 6:03pm |
You only had to forget it was hooked up once. While you were fixing the bale knotter or something else. NEVER do that again!
Then there's the one you hooked to the milk line to do chores when the power was out.... |
