Differences in 6000 Series |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Sep 2018 at 2:14pm |
What are the differences in the 6060 to 6070 to 6080? Seem to be pretty close overall.
What are some issues and setbacks they have? Edited by AJ - 23 Sep 2018 at 2:32pm |
Can't fix stupid
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3512 |
6060 6070 Had the 433t engine, the 6080 the 433I the 6060 had a 8 speed tranny and most had 28" tires. 6070 replaced the 6060 with the 12 speed tranny to overcome a slooow road speed issue with the 6060 rear end. The 6080 had a 540/1000 pto. Cabs/sheet metal were the same as were most other components.
Which transmission is more reliable? What's the difference between the 433T and 433I?
Can't fix stupid
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 811 |
433T is turbocharged, and the 433I is turbocharged and intercooled.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5209 |
We have a 6060 since it was new in 1981. It’s been a very good tractor. Fuel pump had to be rebuilt about 6 years ago. Replaced both clutches this spring. 433t has good power. No transmission issues. Only issue is it is cold natured. Plug in the heater for 30 minutes or hit the ether button below 45 degrees. We try not to use the ether unless we have unplanned need for the tractor. A lot of 6060,6070,6080 tractors in our area. Local dealer is 7 miles away. Highly recommend having one. Also, ours does not have the crankshaft bearing support which was suppose to be installed by the dealer under warranty after issues arose on early 6060’s. Dad was never notified and until a few years ago we were unaware of the issue. We have not had the issue and I believe it’s because we use the pto lever properly. Great tractor for its size.
How many hours are you guys getting out of these engines?
Can't fix stupid
wlambs ![]() Bronze Level ![]() ![]() Joined: 18 Jun 2018 Location: ga Points: 67 |
have 6060 and 6080 . both are good tractors.6080 12 speed so few more choices on working speed.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21752 |
10,000 hrs I have seen three times on 6080's before it was engine overhaul time.
Edited by DrAllis - 24 Sep 2018 at 8:05am |
kev/ont ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Castleton Ont Points: 282 |
we traded a 6080 in at 9800 hrs that the engine had never been touched.
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
My 6080 has 7400 hours. I believe it’s all original. We’ve had it 12 years or so. Had to put a clutch in it. Other than that it’s had no issues and runs strong
Billoh ![]() Silver Level ![]() ![]() Joined: 24 Sep 2009 Location: Nashville Ohio Points: 240 |
I have almost 7000 hrs on mine that I bought new,no problems
murdoc ![]() Bronze Level ![]() Joined: 25 Mar 2011 Points: 32 |
Dr allis I need help I just got a 6060 and the pto won’t shut off they’ve been cranking it in gear to use it you pull back the stage coach handle and it won’t stop I’m thinking stuck clutch but don’t know linkage is moving I need somebody to move the handle while I look to be sure any sugesstions ???
