Differences between 300 & 400 series?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Differences between 300 & 400 series?
    Posted: 18 Sep 2017 at 9:05pm
Looking for a tiller for a 314 Hydro that I just bought. Will a tiller from a 700 or 900 series be the same? What size tiller? Thank you.
Wink
I am a Russian Bot
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 1:40pm
A 36" tiller will work but you need one with the hand clutch on it. On the 300 Series, unless they were updated the rear lift tube diameter is larger than the standard 1" ID tube used on the rest of the Simplicity machines. I think you could make some sort of sleeve or bushing to adapt it or if you found a late 400 Series rear lift, they have the 1" tube.
This page was generated in 0.348 seconds.
