Difference in Gleaner flex head ?'s
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Topic: Difference in Gleaner flex head ?'s
    Posted: 29 Oct 2016 at 9:39am
What's the main difference in the 300, 500 and 800 series flex heads? Im looking for a 24 ft head and there is a 500 series on a sale next weekend with reel drive pump on the head, which is what I need. I think its been said to stay away from a 500 series heads but not for sure. I like the 300 series since I've been around one my whole life. Haven't ever been around anything newer so I need some knowledge on them.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:53am
The 500 head is better than a 300 in my opinion. The cutter bar is 3" closer to the cross auger which helped in short beans, also went to a one piece feathersheet.
800 head the cutter bar was moved back forward to the 300 position and had a larger cross auger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 11:27am
Out of the three models, the 500 is the best for soybeans.
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 12:05pm
My nephew says he will never go back to using the 300 series. Loves the the 525. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 2:11pm
We got a 520 and it's ok.
