Difference Between |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Topic: Difference BetweenPosted: 04 Jul 2017 at 1:17pm |
Hyd/Trans FLUID
and Hyd/Trans OIL ???? I know I've used Universal Hyd/Trans Fluid in everything in my tractors (except the engine and finals) BUT, I bought some Hyd/Trans OIL ......... CAM2 PROMAX™ Tractor Hydraulic 303 Oil 5 Gallon instead of Blain's Farm & Fleet Universal Hydraulic Tractor Fluid Now I have 5 buckets of the 303 and am wondering what to do with it? Is it the same as the fluid?? I'm at a loss. |
Dans 7080
Posted: 04 Jul 2017 at 2:17pm |
Same stuff.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Dakota Dave
Posted: 04 Jul 2017 at 5:23pm |
303 is the spec number for universial tractor hydraulic fluid. Any oil with the 303 spec is compatible and can be used together.
Edited by Dakota Dave - 04 Jul 2017 at 5:24pm |
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1185 |
Posted: 04 Jul 2017 at 6:54pm |
Ted, Although I'm not questioning the learned responses above, I wouldn't risk it. Best if you dropped all of your fluid off at my place and buy new. That way, you have no risk!
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |
Thanks(1)
Posted: 04 Jul 2017 at 11:39pm |
is 303 for wet brake?I didn't think so.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34374 |
Posted: 05 Jul 2017 at 4:13am |
Farm & Fleet universal oil is what I use... Thought I had made a
good deal on 303 Tractor Supply oil, we use to use 303 in the 170 from DX and Texaco and it never caused a problem back then, but this Tractor Supply oil gets real thick
real fast in the winter and the loader didn't want to drop, so changed the oil out to
F&F oil and life was better... and had to remove the 303 out of the
610 Bobcat too or it would not suck it up until it was warmed up.
Now I dump that 303 into the older tractors that get used only in the summer time. |
tomstractorsandtoys
Posted: 05 Jul 2017 at 7:48am |
Yes 303 is for wet brakes. It is the oil used in all Deere 10-20-30-40-50 series tractors built from 1960 on. I think I read somewhere that Deere was the developer of it to use in the trans,final drives,brakes steering ect of the 3010-4010 tractor. Tom
Joined: 11 Sep 2009 Location: illinois Points: 88533 |
Posted: 05 Jul 2017 at 7:42pm |
303 or Universal Tractor fluid or UTF is GREAT STUFF for older equipment. It was designed by JOHN DEERE in the 1970s for their tractors. Since then they have UPGRADED the oil 3-4 times to a newer spec. MANY sell the older 303 as it is GREAT in most equipment... That being said, it was NOT designed to use in high pressure / high volumn/ close tolerance system like a Skid Steer or new Excavator ........ a 40 year old backhoe would do fine......... below is a cut and paste about 303
303 Tractor Fluid: |
Hockeygoon
Joined: 13 Sep 2016 Location: Manhattan, KS Points: 1210 |
Posted: 06 Jul 2017 at 8:43am |
303 is a cheap trans hydraulic fluid that John Deere developed BEFORE the their powershift transmissions - it was the first step up from 90W gear oil. It was dropped in the early 1970s and replaced by Hyguard. It is a decent trans hydraulic oil for tractors with a nonsynchronized transmission but I would never use it in anything with a powershift or hydrostat. Some people say its fine to use in a synchronized transmission but I have no first hand experience with that. We use it in construction equipment as hydraulic fluid only. Think about it, the absolute cheapest motor oil you can buy today (if you look long and hard for some 30W non detergent) is about $2.00 a quart the 303 trans hydraulic fluid can be readily found $1.00 a quart - how much for additives can it possibly have?
