differance in d17 gas lube systems |
Post Reply |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3487 |
Posted: 11 Nov 2023 at 11:13pm |
what are the differance from series 1 to series 4 engine lube systems the pipeing on my two parts tractor engines are alot differant
Orange Level Access Joined: 12 Sep 2009 Points: 20185 |
Knowledge Base near the bottom of page 1. WD-45 full-flow oiling conversion
Edited by DrAllis - 12 Nov 2023 at 2:19am |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80173 |
The "OLD STYLE" uses the Bypass filter with the mason jar thread.. Same as the B,C,CA,WD... etc......... Later in the "D" series they switched to the automotive PH8 full flow filter..( some had the old, then later they had the NEW).. it would have a much larger tube ( maybe 3/8 inch??) coming off the filter housing and screwed into the side of the engine block..
You can not interchange the filters or housings.. Things are different inside.
more on the link from Dave and Dr.
Post Reply | |
