Diesel won't start |
GARY(OH/IN)
Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
Topic: Diesel won't startPosted: 26 Sep 2011 at 5:03am |
Won't start without a shot of starting fluid anyway. This tractor, off color, 5000 Ford has had very little if any use last 6 years. Put on new voltage regulator, charged battery time will tell if battery is still good. Starts with ether but not on it's own. Don't see any glow plugs. How about changing fuel filters? Could they be so plugged from setting for years that injection pump can,t get enough fuel for pressure to start? Other ideas?
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 26 Sep 2011 at 6:19am |
I would go through and replace all the fuel filters, drain it all down and put fresh fuel in it. I had the same problem with my HD3 and that sat for 5-6 years from the last time it ran. Worst part was the injector pump was run dry and allowed to sit, so I ended up having to have the pump rebuilt. Once rebuilt and put back on, it didn't take long to get up and running. Also, if the battery sat dead for a long time, take it off and set somewhere safe and put a battery charger on it, and let it run for an hour or so on jumpstart cycle or high charge, whatever your charger has. It will cook off the plates in the battery and maybe come back to life. It was recommended on here by a few people and since I started doing it, I have revived about 75% of the batteries that I have tried it on. Good luck.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Jeff Z. NY
Posted: 26 Sep 2011 at 8:12am |
It won't start here either.
This is the Allis Chalmers section. http://www.mytractorforum.com/forumdisplay.php?f=20 |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 26 Sep 2011 at 9:04am |
You need a couple of things for a diesel to start easily--------good compression and good fuel atomization. If fresh fuel, clean filters, and good cranking rpm don't result in good starting, I would pull the injectors and have them checked and do a compression check while the injectors are out.
Oh yes, for good cranking rpm, I would recommend using Mobil 1 5w-40 Turbo diesel oil or something similar. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Bull
Joined: 28 Sep 2010 Location: Lamar, Missouri Points: 589 |
Posted: 26 Sep 2011 at 9:54am |
Speaking of compression check, will a starter in good working order spin a diesel fast enough for an accurate compression test?
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 26 Sep 2011 at 9:12pm |
yes bull it will do just fine
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 27 Sep 2011 at 8:46am |
Sounds like an old tired engine. If I remember right that has a CAV pump, not known for good cold starts. I wouldnt spend much on it as its kinda the nature of the beast in my opinion.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5123 |
Posted: 27 Sep 2011 at 10:06am |
If that has a SIMMS/MINIMEC inline pump, there is a start fuel button to push, but since most people who have those pumps don't know it has its own oil sump, linkages are probably rusted up. If its a DPA rotary pump, the head in the pump could be worn out. While it's cranking, does it produce exhaust smoke? Every start hard? hot/cold? good luck. Ed
