diesel hydrostatic wc |
Author | ||
mintenfarmer ![]() Silver Level ![]() Joined: 22 May 2015 Location: Minnesota Points: 191 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Jul 2017 at 9:33pm |
so my latest and greatest idea is to fa up an engine driven hydraulic pump and put a hydraulic motor to drive the rear axle. my question is, would i be better to drive the reaer axle directly or through the transmision with different "ranges"
Sponsored Links | ||
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8654 |
Hydraulic and hydrostatic drive are not the same thing...just sayin
well the goal is a hydraulic driven tractor
As long as you just want fun and unique you'll be fine.Trying to do serious work will not be so rewarding.Ineffecient is the word.
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5604 |
Could you belt drive it from the belt pulley?
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8456 |
IH tried that, didn't they?
Seems it would be good for pulling a combine or doing haying work, but not much else. |
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
If it has a pto, why not put a hydraulic motor on that and run it from there?
ALLIS EXPRESS!
This year: |
Neighbors bought 2 of those little IH gas hydro tractors.Didn't have them long before trading for gear diesels.Said they were GAS HOGS!!!.Yup,hydrostatic is good for for variable speed and reversing but not hard field work. Pumping oil creates lotsa heat which is wasted energy.
Edited by SteveM C/IL - 26 Jul 2017 at 11:33pm |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Most larger tractors with hydrostatic drive still use the transmission.
You need a variable displacement pup to take advantage of the hydraulic drive. Use a second pump on the back of the variable pump for the PTO
Bull ![]() Orange Level Access ![]() Joined: 28 Sep 2010 Location: Lamar, Missouri Points: 589 |
Friend of mine had a 656 gas hydro. It was a great tractor on a disc mower but as previously stated you need a fuel truck in the field.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
