Diesel Engine Oils
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 8:26am
Acquired a 1978 gas engine that would run lower oil pressure with multi viscosity 10w-40 oil. Dealership advised to run straight 30w oil, which immediately raised oil pressure. It’s still running great today on 30w. Any new parts guy at Napa will usually stare at me oddly, when I ask for a case of 30w oil.
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 12:54pm
I have a 6140 w/ the 3 cylinder diesel engine. I intend to use straight 30wt, but do I use non-detergent? It's a 1982.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 1:03pm
I have a 1982 AC 6140 w/ the 3 cylinder diesel engine. I intend to use a straight 30w oil. Should I use a non-detergent?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 1:37pm
Yikes no. Run a modern high quality motor oil. I see you're near PDC. I'd run a multi-vis oil too. Definitely not SAE 30 when the temperature is below 32. What does the manual say? I'm guessing that it wants 10W-30 or 15W-40.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 1:58pm
I use Rotella conventional 15W40 in my 2 tractors, all my small engines and used to run it in my '79 Yamaha motorcycle.
For any diesel or older gas engine, I would recommend it.
1951 B
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 3:33pm
Grandpa bought a Cat diesel tractor in 34, with the dealer being able to bring other customers around to show off the new diesel engine. Started burning oil right from the start. Not what Caterpillar company or the dealer wanted,or grandpa for that matter. Was the newest high tech of the day, but unproven at the time. The bolts about learned to unscrew themselves they had that engine apart so many time. After new rings, then pistons and rings,and finally sleeves,pistons,and rings and a brand new oil with detergent it ran without oil consumption.
The detergent oil was developed to help remove the carbon and other by products of burning low grade fuel, that we know today as diesel fuel.If ever a engine needed detergent oils its diesels.
Will not get into the straight or multi weight oil argument. But have been convinced by a engine machest that we don't need as much oil pressure to keep a engine going as we generally think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 5:09pm
Actually the manual says not to use a multi vis oil.
I mainly use the tractor for brush hogging, so I thought a straight 30w would be ok. Don't use it during winter pos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 6:07pm
Originally posted by bigal121892 bigal121892 wrote:
Dad bought the combine used from the local dealer, we got it home, changed all of the fluids, and put 15W40 in it just like we had in everything else. Combine used two gallons of oil the first day. Called dealer, (thinking we were sold a combine with a bad engine) dealer said drain the 15W40 out, and put straight 30W in. Did that, and the combine would use a quart every 100 hours until it was traded 3 years latter.
Two gallons in a day? He would have almost had to be dumping a quart in every hour. How much was it smoking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 6:02am
Higher oil pressure does not mean higher oil flow. The last thing I want at startup is high oil pressure. That means the thick oil isn't reaching the upper parts of the engine fast enough. Detergent or non-detergent shouldn't make any difference as far as oil consumption is concerned with a new engine. Non-detergent may give you higher oil pressure as the engine ages. This is because the ports may be starting to clog. Cheap oil may make a difference. The cheap stuff may be vaporizing much faster. Every engine is different, especially during the break-in period. Testimonials don't mean much to me unless I know every circumstance of the conditions when the oil pressure or consumption was noted.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 6:53am
I can see no reason to use anything different than what the manufacturer recommends in the owners manual. These companies hire engineers to develop engines. Many have different oiling systems (like the new high flow systems that have been around in cars for ~ 15 years). Why would anyone think they know more than the engineers that designed the engine???
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 9:09am
It's not about knowing more.  It's about modern lubricants being much better than anything the engineers dreamed of 30 or more years ago.  That being said, stick with the recommended viscosity, more or less, but if a manual recommends 10 in the winter and 30 in the summer, that's essentially what you are giving it with a modern 10w30 which is a far superior oil than 10w30 was in 1960 whatever.
Edited by HoughMade - 27 Aug 2019 at 9:10am
1951 B
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 9:41am
Originally posted by festus51 festus51 wrote:
I might get the evil eye from some people ,  but I got tired of stocking multiply oils for all the different engines I have.  Quite a few years ago I started putting 15-40  diesel oil in every thing.  Pick ups, car, tractor diesel engines. gas engines , motorcycle, lawn mower .
sure simplifies oil buying.  I figure it is a step above gas engine oils with high detergents plus the higher pressures of diesel engine.  I have had no problems yet  knock on wood.
X 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 12:29pm
This.
I'll put up any of today's diesel rated 10W-30 diesel rated motor oils up against any SAE 30 motor oil of 25 years ago for that diesel engine. Hands down todays oil is superior. The old single viscosity oil was the only way they knew how to build an oil with sufficient film strength. The old advertisement where they said that 80 percent of engine wear occurs in the first 10 minutes of warmup was true. You need to get your oil circulating as fast as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2019 at 7:13pm
DOUG.... HOUGH...... Thumbs Up    Thumbs Up   Thumbs Up
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2019 at 11:17pm
For those that reference the manual for recommendations, a first year 7060 book warns against using multi-vis oils, but a last year 7060 book approves them.
What do you do then? ;)
I run Mobil Delvace 1300 super 15w40 in everything of mine with a diesel engine.
My road pickups that are around little dust and put enough miles on that extended intervals can save some $ get full synthetic 5w40. Ben running Valvoline but I just scored a deal on some Mobil delvac ESP 5w40, so its going in next.
A seasoned mechanic told me once that he sees more issues caused by improper cooling system servicing (electrolosis, etc. ) than he does engine oil caused faults.
We get all wound up about what oil to use, but dont seem too concerned about the 15 year old antifreeze in the radiator...
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 7:23am
Let's start a which antifreeze is best thread. :) Actually back in the good old days you could mix and match antifreeze brands. Now you have to break out your color compatibility chart, lest you create a brown slush in your coolant. When an antifreeze company posts that their product is "compatible with all other antifreezes", it ain't necessarily true.
Things are different from what they were 25+ years ago.
This page was generated in 0.311 seconds.
