Diesel Engine Oils |
Page <12 |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3534 |
Acquired a 1978 gas engine that would run lower oil pressure with multi viscosity 10w-40 oil. Dealership advised to run straight 30w oil, which immediately raised oil pressure. It’s still running great today on 30w. Any new parts guy at Napa will usually stare at me oddly, when I ask for a case of 30w oil.
Stanley ![]() Bronze Level ![]() Joined: 16 Oct 2009 Location: PDC, WI Points: 193 |
I have a 6140 w/ the 3 cylinder diesel engine. I intend to use straight 30wt, but do I use non-detergent? It's a 1982.
I have a 1982 AC 6140 w/ the 3 cylinder diesel engine. I intend to use a straight 30w oil. Should I use a non-detergent?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Yikes no. Run a modern high quality motor oil. I see you're near PDC. I'd run a multi-vis oil too. Definitely not SAE 30 when the temperature is below 32. What does the manual say? I'm guessing that it wants 10W-30 or 15W-40. |
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 707 |
I use Rotella conventional 15W40 in my 2 tractors, all my small engines and used to run it in my '79 Yamaha motorcycle.
For any diesel or older gas engine, I would recommend it.
1951 B
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4734 |
Grandpa bought a Cat diesel tractor in 34, with the dealer being able to bring other customers around to show off the new diesel engine. Started burning oil right from the start. Not what Caterpillar company or the dealer wanted,or grandpa for that matter. Was the newest high tech of the day, but unproven at the time. The bolts about learned to unscrew themselves they had that engine apart so many time. After new rings, then pistons and rings,and finally sleeves,pistons,and rings and a brand new oil with detergent it ran without oil consumption. The detergent oil was developed to help remove the carbon and other by products of burning low grade fuel, that we know today as diesel fuel.If ever a engine needed detergent oils its diesels. Will not get into the straight or multi weight oil argument. But have been convinced by a engine machest that we don't need as much oil pressure to keep a engine going as we generally think.
Actually the manual says not to use a multi vis oil.
I mainly use the tractor for brush hogging, so I thought a straight 30w would be ok. Don't use it during winter pos.
Two gallons in a day? He would have almost had to be dumping a quart in every hour. How much was it smoking? |
Higher oil pressure does not mean higher oil flow. The last thing I want at startup is high oil pressure. That means the thick oil isn't reaching the upper parts of the engine fast enough. Detergent or non-detergent shouldn't make any difference as far as oil consumption is concerned with a new engine. Non-detergent may give you higher oil pressure as the engine ages. This is because the ports may be starting to clog. Cheap oil may make a difference. The cheap stuff may be vaporizing much faster. Every engine is different, especially during the break-in period. Testimonials don't mean much to me unless I know every circumstance of the conditions when the oil pressure or consumption was noted.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5022 |
I can see no reason to use anything different than what the manufacturer recommends in the owners manual. These companies hire engineers to develop engines. Many have different oiling systems (like the new high flow systems that have been around in cars for ~ 15 years). Why would anyone think they know more than the engineers that designed the engine???
It's not about knowing more. It's about modern lubricants being much better than anything the engineers dreamed of 30 or more years ago. That being said, stick with the recommended viscosity, more or less, but if a manual recommends 10 in the winter and 30 in the summer, that's essentially what you are giving it with a modern 10w30 which is a far superior oil than 10w30 was in 1960 whatever.
Edited by HoughMade - 27 Aug 2019 at 9:10am |
1951 B
nella(Pa) ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3124 |
X 2
This. I'll put up any of today's diesel rated 10W-30 diesel rated motor oils up against any SAE 30 motor oil of 25 years ago for that diesel engine. Hands down todays oil is superior. The old single viscosity oil was the only way they knew how to build an oil with sufficient film strength. The old advertisement where they said that 80 percent of engine wear occurs in the first 10 minutes of warmup was true. You need to get your oil circulating as fast as possible. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87864 |
DOUG.... HOUGH......
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
For those that reference the manual for recommendations, a first year 7060 book warns against using multi-vis oils, but a last year 7060 book approves them.
What do you do then? ;) I run Mobil Delvace 1300 super 15w40 in everything of mine with a diesel engine. My road pickups that are around little dust and put enough miles on that extended intervals can save some $ get full synthetic 5w40. Ben running Valvoline but I just scored a deal on some Mobil delvac ESP 5w40, so its going in next. A seasoned mechanic told me once that he sees more issues caused by improper cooling system servicing (electrolosis, etc. ) than he does engine oil caused faults. We get all wound up about what oil to use, but dont seem too concerned about the 15 year old antifreeze in the radiator... |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Let's start a which antifreeze is best thread. :) Actually back in the good old days you could mix and match antifreeze brands. Now you have to break out your color compatibility chart, lest you create a brown slush in your coolant. When an antifreeze company posts that their product is "compatible with all other antifreezes", it ain't necessarily true. Things are different from what they were 25+ years ago. |
Page <12 |
