Diesel coolant cavitation
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 8:59pm
Thanks Gerald. Was under the impression it was a chemical reaction, I learned something new today! Guess a person is never too old LOL!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 5:43am
Had the definition of electrolysis in school a long time ago but I went and looked it up just to get it right. I'll put it here in my own words...........Electrolysis is an electro-chemical reaction between different metals. Just like how some folks on the forum have cleaned rusted metal parts immersed in some form of conductive liquid and opposite some home made electrodes and using a battery charger hooked up to each metal. Leave it charged long enough it will eat away at the good metal too.
Then there is just plain oxydation which is simply corrosion.
Both of these and cavitation that a diesel is prone can kill an engine given enough time.
These are three different problems and cavitation is the biggest problem in a diesel IMO.
Edited by Lonn - 28 Dec 2017 at 5:45am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 9:41am
the film I saw that Cummins put out,said the liner expanded under firing and "snapped back" in place causeing void between water and wall causeing high heat on wall surface.When water moved back to wall,it was boiled and that steam bubble would blow a hole in metal (little by little). The additive coated liner to form protective layer to offset "steam damage". It doesn't change what's going on,it just protects against damage. This is for cavitation erosion.Electrolisis is different animal.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 12:30am
Cat EC-1 equivalent is an excellent diesel coolant that is available anywhere, and many aftermarket coolant makers offer a EC-1 equivalent.
I need to find a coolant filter without the additive brick inside, as I still value the filtering ability of having a filter, but I would imagine running a regular pre-charged filter is a no-no with extended life coolant.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 9:28am
I don't know for sure but I think the coolant "filter" is really a device primarily intended to keep the additive amount up and there isn't any coolant cleaning in the can.
Gerald J.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 9:36am
Gerald J.
Clap  This is what I was told back in 1969 when working on the late stock/repair floor when I was given the task of installing these "coolant filters" on a couple of dozen 11,000 series engines before they were shipped.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 9:59am
Gerald J.
They do indeed have filter media in them and they do filter the coolant. When IH came out with the coolant filter kits we installed a lot of them on older tractors. We had several that after several days the the filter quit warming up when the engine was run. We cut the filter apart and it was completely plugged with the brown sludge that you typically see at the bottom of the block when you pull a wet cylinder liner out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 7:52pm
Picked this up at Rural King. Has the additive in it.
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 8:34am
Bump
theropod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 11:06am
I have an EL-300 Kubota single cylinder diesel engine that makes about 4.25 HP on a good day. We use it to drive a large frame alternator to recharge our battery bank when the sun doesn’t shine and wind doesn’t blow. It runs at about 1,650 RPM. Is my little engine at risk from this effect? It is a wet sleeve engine, with a little over 10,000 hours and runs like a champ.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200
No private messages:
use email:
theropod AT yahoo DOT com
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 11:48am
That little Kubota probably don't have enough bang to swell liner on power stroke but I would follow Kubota's direction on your coolant.HD coolant can't hurt it though. 10,000hrs is a lot so you're probably ok either way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 1:27pm
My owners manual and shop service manual don’t mention anything about special coolant/antifreeze. Owned the engine since new over 17 years ago. Never been seriously hot. Changed oil like clockwork. Kept the valves adjusted. Take the injector out/apart ever so often and soak in lacquer thinner. Take the radiator off once a year and pressure wash the thing and the sleeve looks pretty clean. A really sweet engine that the EPA has banned.
use email:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:28pm
that right there tells you how smart the GOV is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 9:29am
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 11:57am
Coolant filters are a good idea to add to your 6.0/6.4 powerstroke. On the 6.0 mostly to catch the debris that will clog the oil cooler. Using a precharged filter is a no no as that will clog the cooler too. 6.4 has problems with cavitation on the front cover right behind the water pump. When the Ziegler Cat people were running 6.0s they switched them all to Cat EC1 and then I did far fewer oil and EGR coolers on them.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 12:17pm
Baldwin does offer some coolant filters without any coolant treatment in them. Don't know about all applications though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 8:44am
I just found Peak "Final Charge Coolant " at
Menards for $11.49 per gallon. Label says it meets
many manufacturers including Cat EC-1 and Cummins.
Should be under $60 for a refill.
Thanks for the information..
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 6:50pm
You didn't fall for the "PREMIXED" anti freeze, DID YOU??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 8:37pm
Bob, did you mean Fleet Charge? Does it look like what I put in my post above? If so, its full strength not a 50/50 mix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 8:26am
Thanks I am trying not to buy water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 11:07am
There is a difference in pre mixed vs full strength other than one is ready to use and the other requires mixing. Premixed uses de ionized water. Probably not as big of a concern in the diesel world unless there are electronics being cooled as well.
This page was generated in 0.313 seconds.
