Did I go wrong????
 Post Reply Post Reply Page  <123
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 9:27pm
Std. timing and install a pyrometer. You are going to be dumping more fuel into that engine against a push and it will smoke more with additional heat in the exhaust. A pyro will help you keep this in check.
Myself I would stay with the originals HV6 series. A turbocharged engine takes to uprating of injectors much better than a natural aspirated engine does. Hate to see you melt your hard work down.
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 9:16am
https://www.allischalmers.com/forum/hv7-injectors_topic187206_post1597904.html?KW=HV7#1597904
I thought the HV7s were OK to run in the 271 without problems???? I guess I’m confused. I surely don’t want to damage the engine after all this.
Edited by COD - 28 Apr 2022 at 9:18am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 10:06am
just a little more fuel,  shouldnt hurt anything, but if you can stay with same size.
Edited by CAL(KS) - 28 Apr 2022 at 10:10am
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 12:19pm
Is anyone else out there running HV7s in their 271? If so any issues?
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 1:33pm
Since no one else seems to be running the HV7s in their 2-71, does anybody have any good HV6s they want to sell?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 3:12pm
HI  I have some HV6  injectors
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 7:11pm
PM sent Gemdozer
COD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COD Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 12:15pm
If I use HV7 injectors what is standard timing for those? Is it 1.484 or 1.460????
This page was generated in 0.159 seconds.
