Did I go wrong???? |
Post Reply | Page <123> |
SophyCi
Bronze Level Joined: 19 Jan 2022 Location: Tampa Points: 4 |
I think you did well! It appears that with a little TLC, you will have a great toy to play with.
COD
Bronze Level Joined: 01 Jan 2022 Location: Mississippi Points: 52 |
So I’ve got the engine and engine clutch out. I have removed the engine clutch, clutch housing, flywheel, and the bell housing. I’ve got to get longer bolts to bolt it to my engine stand so I can start the tear down. One question though. When I was removing the assembly from the dozer I accidentally pulled the locking plunger out too far. How do you line this thing back up? What does it attach to inside the gear shift housing? The service manual and parts manual are unclear.
COD
So I got the engine tore down. How do you tell if the liner is a 1, 2, or a 3? I don’t see anything marked on it that would denote which one it is.
200Tom1
Orange Level Joined: 03 Jun 2019 Location: Iowa Points: 1200 |
Good luck with her. I wish I had kept my last HD 6. Sure miss that clank, clank.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22234 |
how ? Have AFIS check that fingerprint !!!! Now a clever parts numbering guy would make 5149211 a '1', 51492112 a '2' .... More 'numbers' fun.... my BUDA 4BD153 can have either a 3 or 4 ring set per piston...HOW can anyone tell BEFORE tearing it all apart...sigh..... same boat, different paddle. |
COD
Lol. I realized it after I posted the pic. Hope there is no one with the FBI on the forum!😂
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 30638 |
Used to be listed in the DD service manuals, that and the micrometer dimension of the sleeves. The mark is also at the top so will be a heavy or thicker 1, 2 or 3 sleeve.
I no longer have my manuals. |
COD
When you say heavy does that mean oversized where the block has been bored or just a thicker liner from factory?
COD
Found this on PC Industries website. Is this info correct? I don’t have a micrometer large enough to measure the outside diameter of the old sleeves.
COD
Well after calling several places, I got several different answers so I’m even more confused now.
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 2022 |
This is where the block and liners need measured by someone that has the tools and experience with the Detroit engine series. Not being sarcastic or anything of the type but the block bore needs to be known, and round to fit correct liners, then protrusion of the liners etc. More to it than just a guess. Any competent machine shop on diesel engines should be able to measure it up for you to eliminate guesswork.
Very easy engine to build but you have to know the correct sized parts are going into it.
COD
After talking to pc industries, Heavy Duty kits, and diesel pro power, all three confirmed the part number from the liners I removed are a standard size three. I figure if it ran with them before it will again. Putting the micrometer on everything else, it appears this engine was rebuilt shortly before it was parked. There is also no ring ridge whatsoever in the liners. If water hadn’t gotten into that one cylinder this thing would have popped off and ran for years I believe.
COD
Got a question. My block serial number is prior to them using the longer cam bearings. Mine are 1-1/8 long and the “newer” blocks are 1-1/2” long cam bearings. The blocks appear to be the same part number and so do the cams (according to the part numbers). The 1-1/8” standard size is made from unobtainium and not available. They make a .015 under bearing for $35 per bearing. Problem is no one around here grinds camshafts. The 1-1/2” wide ones are $11 per bearing and standard size is available. Can I use the 1-1/2” wide ones as long as the oil holes line up? Basically about 1/4” of the bearing will be sticking on the inside of the block past the bore for the cam bearings. The oil holes in the 1-1/2” wide bearings appear to be off center so I think they would line up. I mic’ed my cam bearing journals and they are within spec but I may polish them a little in a jig to spin the cam using a drill and a socket.
Any thoughts guys? |
fjdrill
Silver Level Access Joined: 13 May 2012 Location: Alabama Points: 279 |
Did that 5 come from over around Scooba?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80117 |
Dewey , if the bearing OD is the same and will fit in the block... I would think you could take a cutoff wheel and trim some off the bearings "if needed"... maybe OK they way they are.
COD
I got it from a fellow that was South of Dekalb, MS so it wasn’t far from Scooba.
COD
Thought about trimming the bearings off but had rather leave them sticking a little past the bores unless it would be an issue. I don’t see where it would be but I’ve never seen an engine with bearings sticking out past the bores.
fjdrill
I’m thinking that my dad’s old dozer. Bought about 1965 in Amory at a sale at one the AC dealer auctions. First dozer I ran pulling a Rome new ground disc. About 1969-70 ( I was like10 years old at the time) sold to a local. Then a Mennonite had it in Geiger Al Wondering were it went. Figured scrappers had gotten it.
COD
The scrappers were next in line to get it. It’s still a solid old dozer seems like. If water hadn’t gotten into that one cylinder it would have fired off. I like to save this old iron. It was built in days where things were simple and made to last. You can take a set of wrenches and sockets and work on anything on it. Glad it brought back memories for you.
Edited by COD - 27 Mar 2022 at 6:28pm |
COD
It had the rear aux hydraulic hoses on it. Figured it was pulling a disc at some point.
Anybody else got any feedback on the cam bearings??? Edited by COD - 27 Mar 2022 at 6:28pm |
COD
Anybody got one of these in good shape they are willing to sell???? If so PM me
Codger
The throwout bearing fork is a common part to build up with either weld, or brass.
COD
The forks are in great shape. My problem is the jetway on the long shaft said is worn causing a lot of play.
DMiller
"Key" way??
COD
Oops. Yes keyway. I didn’t catch the autocorrect had changed it.
Codger
Most any machine shop could cut another Woodruff keyway into the shaft 180 degrees opposite from the existing worn keyway(s). I just had that performed on an overhead crane hoist last week rather than spend $340.00 from Budgit Hoists for a replacement shaft.
COD
Great idea! I didn’t think of moving the keyway around.
COD
OK guys I have another dumb question. I’m in the process of reassembling the engine. I am ready to put the rings on the pistons. I have looked all over the four compression rings and do not see any markings that would denote the “top” side of the rings. It’s Interstate McBee brand. I called the place I bought the kit from and they said it didn’t matter which way was up but didn’t give me a fuzzy feeling they knew what they were talking about. Anybody know for sure on this?
Codger
they may be correct if no markings. Most compression rings have a slight taper which goes to the top but not all.
COD
Just in case anyone else runs into this issue this may save you the trouble I went through to find out for certain on the piston rings. I contacted Intersate-McBee’s customer service and explained the issue to them. The first two people were as unsure as I was. They finally got an answer back to me today that it doesn’t matter up or down on the compression rings.
On another note, my next question is this; I’m using HV7 injectors instead of the HV6. Reason being I got some rebuilt ones for a really cheap price. What should I set the injector timing to for the HV7s? |
