Deutz Allis 1920 smokin like a freight train
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Deutz Allis 1920 smokin like a freight train
    Posted: 30 Mar 2012 at 11:29am
Got a 1920 DA \Simple garden tractor with a 20 horse Kholer - it was running great , now you can be cutting grass and suddenly it will just start smoking like a train for a bit then clear up and run perfect again , any suggestions ?
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 11:35am
To much oil.It will stop...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 11:47am
The oil levels right on full - wonder if brokin rings would do that just sometime ?
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 3:14pm
It might be that oil is being sucked into the carburetor through the crankcase breather. I am not familiar with that engine but many engines pull their crankcase ventilation from the pushrod or valve spring area. If surplus oil can't get back to the crankcase quickly enough it will get pulled over into the intake to the carburetor.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 11:31am
When was the last time you pulled the shields and cleaned the grass out of the fins??  Hot engines equals lost temper in the rings.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 1:00pm
to much oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 1:02pm
Done all that a couple weeks ago; with a major tune up
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 1:30pm
What color was the smoke? Black or Blue.
Lars(wisc) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wisc) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 2:30pm
crankcase ventilation problem
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 3:23pm
got a free rider a year ago with the same problem 15.5 horse briggs, turned out to be just a bad head gasket, runs perfect with no smoke
