Detroit 6-71 Parts
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: Detroit 6-71 Parts
    Posted: 03 Feb 2012 at 6:17pm
Anybody looking for some Detroit parts?  My Dad is cleaning out his garage, He has enough to put one 6-71 together, new liners, pistons etc. rebuilt blower, and almost enough for a second (no second block).  Also has a Fuller RTO9513 13 speed transmission.  219 663-1274
Thanks
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 8:08pm
Claus, I think to myself that I should probably have those parts, because some day I may need them, but then reality sets in. If I were to take them, then in about 20 years, my kids would be placing an ad very similar to yours! LOL. Darrel
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 9:28pm
I have the same disease Darrel! LOL
I am still confident of this;
Wait for the Lord;
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 5:05am
Claus
Is that the same engine that Chevy had in some of there big trucks?
If so I have a friend that is in need of a water pump. Cost shipped to Burkburnett, TX 76354?
Thanks for you time
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:52am
Gary I think you are talking about the 8.2L V8 Turbo Diesel, a Detroit 6-71 is totally different,2 stroke, 6 cylinder,blown motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 5:42pm
Claus
No this is an in line 6, detroit, I thought it was a 6-71.  He has it on the farm and used it to haul wheat, we were going to use it to haul some dirt a few month ago and the water pump leaked all of the coolant out.  Not sure of the year of the truck, but it is a detroit about a 80 something year model hauls about 18,000 lbs.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 5:51pm
Yeah GM ran them in tons of trucks.....seeing how GM built the engines lol. 6-71 were inline 6's and I think the 6-53 was a V6 I'm pretty sure.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 6:36pm
Actually I believe you could get a 71 in either inline6 or V6, believe they had 3, 4, 6, 8, 12 and 16 cylinders.  I believe the 53 and 92 were much the same way.
Gary, as for the water pump all I can tell you is give my Dad a call.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 6:56pm
There were 2 cylinder GMs too.
Gerald J.
Steve-SW Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-SW Pa. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 10:02am
Have 453 factory in a 1962 Studebaker.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 12:05am
I have a '63 Chevy C80 with a 6V53, was used to haul cars from the factory.  Used it myself as a farm truck.  Now it has had a building setting on the flatbed.  May get the building on a foundation this year, it's on the list.
Allis Express participant
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:15am
You can get most of the 2 stroke in an inline or V configuration
6-71 is an inline six cylinder with 71CID/per cylinder
6v-71 same as above only a v6 instead of inline
12v-71 would be a V12 with 71CID/per cylinder, or in basic terms,  2 6V-71 hooked together
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 2:01pm
12V92's are 2 6's bolted together using 4 heads and valve covers just as the 16V92's are 2 8V's bolted together.  12V71's I have seen are one piece block and use inline 6 heads and valve covers but the 16's are 2 8V's like the 92's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 2:22pm
I guess I should have clarified my statement more. Steve is correct in what he said, and thats what I met, 12V71 is a one piece block(all I have seen, maybe someone out there has seen them different) but a 12V92 is really 12 v6's hooked together...
When I first started wrenching we did a tune-up for the local oilfield company. 16V149 pump engine on a flatbed trailer.....2384CID.......she made alot of noise
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 3:21pm
So if anybody needs parts.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 3:48pm
You have to be careful on the sleeves on a 71 series, they are NOT all the same size externally.  There was a factory ink stamp on the sleeves as they shipped them new, a mark toward the top of the sleeve was a tad bit light on dimension while a mark to the lower was a tad bit heavy.  A 'Standard' bore sleeve could be +/- .002, a .010, .015, .030 was the same for dimension stability.  I overhauled a great deal of the 6L-71, 6&8V-92 and a few 6V-53 in my career and only the 71 was a dry fit sleeve, the other two being wet liner around the combustion area.
If you install a 'loose' sleeve, one that falls easily into the bore it will fail at the intake ports under load or not transfer heat very well and gall piston to bore then tear the sleeve in half at the ports(can ruin a block).  If you have to drive them in they will gall severely in the first few hours of operation and then smoke the crank from excess pressure.  Been there, done that with too many guys trying to OH their own on the cheap.  We used a Sunnen Hone to fit the liner bores for the sleeves to fit a snug slip fit from top to bottom and required a intake port tool pusher to bring them back out.
I have several engines I OH'd years ago still plodding the backroads, most are not quality equipment enough for interstate anymore but set up just as described above.
I still have my liner stuffers(put pistons in from bottom of sleeve) to load sleeves/piston/rod at same point of time, for 92,71 and 53 engines.  Did OH a few 110's but too big and expensive to buy my own equipment, used a friends but he has long passed and the tools now gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:42pm
Those liner stuffers are near a must.Would be very tricky trying to install with a plain jane ring compressor.GM also marked the 92 liners for flange thickness in a similar fashion(ink mark location). Lotta people had bad things to say about the 'ol 2 cycles but most were a result of the people who worked on them that didn't know what they were doing. More to it than meets the eye when setting rack and timing too.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:55pm
looking for a muffler for 6/71 that bolts directly to head not mounted on exhaust manifold above engine.   exhaust exits top/ front of muffler.  used on HD15 crawler
This page was generated in 0.150 seconds.
