Detroit 2-71: Starting Methods
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Detroit 2-71: Starting Methods
    Posted: 30 Jan 2011 at 6:44pm
What's the forum's recommendations on cold weather starting?
Does the engine need to turn over a few times before starting to get the lube oil flowing?(I usually heat the oil to about 40 to 50 deg F before cranking engine).
Some guys put ether directly in the blower, but I spray it into the air cleaner to allow some turnover.
Opinions appreciated..............O_O, aka Hedge Apple
Why is there never time to do it right the first time, but always time to go back and fix it?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:57pm
I normally spray the air cleaner. It doesn't really matter how or when you get the ether into it. No more speed than you have cranking the oil hasn't had enough flow to make any difference. The only thing that might matter is the condition of the batteries as they should be good enough to last until the ether gets it running.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 8:53pm
I put the either in through pipe plug in blower, do not need as much that way , generally turn over engine a couple times just to check battery to be sure it turned over then add the either. So while turning over give it a poof, and another as it fires. Have throttle about 3/4 open and as soon as it starts move it back to idle
 figure that pipe plug is where the either capsul drained to on origonal cold start on machine.
Edited by Coke-in-MN - 30 Jan 2011 at 8:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 11:50am
I have never had to either my hd5. If it is around 30 or above i can get it started by cranking on it as long as the batterys are good. I crank on it until it starts to smoke then stop and wait about 15-20 seconds then start cranking it agian and it will fire. I have the throttle about 1/4 open and no heat and no either. Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 12:59pm
Find that below about 40 F I use either , just saves a lot of cranking . Below that temp it is almost a must with most detroits. One nice thing i have converted to key start so I can stand on track and reach both key and the hole in blower . If it is not cold out i will give a shot of either to air pre-cleaner intake from seat to start it .
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 4:51am
i remove the precleaner to get a straight shot at the air cleaner. i definately get it cranking before giving it the ether. if it is real cold, i will crank and let it sit for 15 sec. and then crank again and give it the ether. i agree, under 40 degrees is a must for ether to save on the starter and batteries.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:24am
The last detroit I had was a 3-53 in a tree farmer skidder in  about 1984. From 30* down to o* starting fluid in air cleaner then from o* to -20* I would preheat engine with hot water hoses with quick couplers hoked to pickup heater hoses, below -20* I stayed home!
This page was generated in 0.071 seconds.
