Detroit 2-71: Starting Methods |
Osage_Orange
Topic: Detroit 2-71: Starting MethodsPosted: 30 Jan 2011 at 6:44pm |
What's the forum's recommendations on cold weather starting? Does the engine need to turn over a few times before starting to get the lube oil flowing?(I usually heat the oil to about 40 to 50 deg F before cranking engine).
Some guys put ether directly in the blower, but I spray it into the air cleaner to allow some turnover.
Opinions appreciated..............O_O, aka Hedge Apple
Why is there never time to do it right the first time, but always time to go back and fix it?
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 30 Jan 2011 at 7:57pm |
I normally spray the air cleaner. It doesn't really matter how or when you get the ether into it. No more speed than you have cranking the oil hasn't had enough flow to make any difference. The only thing that might matter is the condition of the batteries as they should be good enough to last until the ether gets it running.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42208 |
Posted: 30 Jan 2011 at 8:53pm |
I put the either in through pipe plug in blower, do not need as much that way , generally turn over engine a couple times just to check battery to be sure it turned over then add the either. So while turning over give it a poof, and another as it fires. Have throttle about 3/4 open and as soon as it starts move it back to idle
figure that pipe plug is where the either capsul drained to on origonal cold start on machine.
Edited by Coke-in-MN - 30 Jan 2011 at 8:55pm |
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3813 |
Posted: 31 Jan 2011 at 11:50am |
I have never had to either my hd5. If it is around 30 or above i can get it started by cranking on it as long as the batterys are good. I crank on it until it starts to smoke then stop and wait about 15-20 seconds then start cranking it agian and it will fire. I have the throttle about 1/4 open and no heat and no either. Matt
Coke-in-MN
Posted: 31 Jan 2011 at 12:59pm |
Find that below about 40 F I use either , just saves a lot of cranking . Below that temp it is almost a must with most detroits. One nice thing i have converted to key start so I can stand on track and reach both key and the hole in blower . If it is not cold out i will give a shot of either to air pre-cleaner intake from seat to start it .
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 01 Feb 2011 at 4:51am |
i remove the precleaner to get a straight shot at the air cleaner. i definately get it cranking before giving it the ether. if it is real cold, i will crank and let it sit for 15 sec. and then crank again and give it the ether. i agree, under 40 degrees is a must for ether to save on the starter and batteries.
B26240
Posted: 01 Feb 2011 at 7:24am |
The last detroit I had was a 3-53 in a tree farmer skidder in about 1984. From 30* down to o* starting fluid in air cleaner then from o* to -20* I would preheat engine with hot water hoses with quick couplers hoked to pickup heater hoses, below -20* I stayed home!
