detailing manufacturer's marks
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: detailing manufacturer's marks
    Posted: 16 Apr 2012 at 1:01pm
Still trying to figure this one out. If there is and easy way or not.
As one would expect on these old tractors, the maufacturer's marks and serial numbers are full of rust and paint. once the metal is prepared otherwise the result is being able to see the marking from the contrasting paint left in the stamp mark and the clean metal.
even with paint remover/ wire brushes it's not easy to clean out these spots. mechanical methods might damage the metal leaving more of a free hand carving look.  Has anyone mastered this skill?
The markings in the expantion plugs(example) are quite fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 2:23pm
On Antique cars, when it came to "cleaning up" the original VIN numbers because the frame was pitted from rust, I used to use a small engraver and traced over the VIN number to make it more distinct. I would think it would work on a Tractor as well.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 2:38pm
Thanks Steve
I had thought about that.  Too many years in construction for me.  I no longer have fine motorskills, not good enough to engrave anyways.... though I might employ the help of a friend to do that.  I just can't seem to get it cleaned out otherwise.
BTW I have those photos of the parts I need...when I get home the camera should be charged so I can get them onto the computer.
Edited by Redwood - 16 Apr 2012 at 2:40pm
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 2:48pm
I would suspect soda blasting would do it..........but, soda blasters are not common
I am still confident of this;
Wait for the Lord;
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 3:22pm
  HEAT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:36pm
interesting thought with the heat.  I assume the acetylene might be just about right if I get fustrated enough.....jk
