Delco Starters etc
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: Delco Starters etc
    Posted: 22 May 2015 at 8:40pm
Might be useful, Delco Remy is now Remy International.
If anyone is tracking their electrics, and have Delco part numbers, go to
http://remyinc.com/Productsupport.aspx
Then click the E-Catalogue box and enter the Delco number and see what comes up.
I found this in researching a starter problem on our AC 45 grader - in that case the original starter number leads straight to a modern drop-in replacement (M 42).
However my auto electrician (very practical, unfortunately near retirement) straight way said "Avoid and get an M 40"
I haven't needed to try for other parts
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 9:24pm
Replaced the starter on all the HD5 machines i have had with the M40 - had a outfit that gave me a good core rebate  for the old starters and with new ones with solenoid one could put key switch on machine .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 10:53pm
Coke
Our 45 has the starter with the solenoid so it was mostly already wired. It now has a second solenoid to lessen the load on the key switch - on advice of that same autolec
